Life-Size Alien Queen Statue From Aliens
Intro: Life-Size Alien Queen Statue From Aliens
Before I made the Power Loader (https://www.instructables.com/id/Life-Size-Power-Loader-Costume-from-Aliens/), I made an Alien Queen. Full sized was the only way to go. This Instructable will show how I made her, cheaply and quickly.
STEP 1: Inspiration and Goals
At one point or another, I remember having seen all of the Alien movies in my youth. I'd always remembered the xenomorphs, but specifically the Alien Queen. She's like the T-Rex of the alien world. As the end of the summer neared, I wanted to make a really cool project to finish off the break. I'd recently made a Velociraptor statue out of foam boards and plaster strips, among other things, and wanted to expand on the methods I used in that project. It seemed that it would be possible to make a full-sized Alien Queen.
I discovered plaster strips last year when I made a Predator costume. They were lightweight and very strong. I began to experiment further with them, trying to make a sort of statue with them. I used foam boards (found at craft stores) to make a sort of skeleton/frame, and then covered that with plaster strips to fill out the shape, which could then be painted. The Velociraptor I made was a good test to see the extent of what could be done with the method.
This was the first project that I did a lot of research for. On previous projects, I might have simply found a few reference images to go off of, maybe watch the scenes from the movie. But this time, I wanted to reach a higher standard of quality; I wanted this to be extremely accurate. So I went through the Queen's scenes in Aliens, as well as going through the behind-the-scenes featurettes and image galleries. I fell more in love with the design and how she was created, and it gave me motivation to do justice to the classic monster. I had a statue of her (made by Palisades) that I used for some reference, but after looking at my research images, I found that the statue was inaccurate in a lot of areas, so I always double-checked to make sure a detail I was making was accurate.
Those were my main goals for this project: to make her life-sized and accurate in detail. And, as always, I wanted to make it cheaply. The size was huge, but since the Queen's legs and arms were pretty thin, that would cut down on the amount of plaster strips that would be needed for it, and I would still be able to keep a modest budget. I also wanted her to be free-standing. I'd have to figure out some sort of support to go under the front half of the figure, since she was so top-heavy and the legs are so far back on the torso.
Another issue with her size was that I would ultimately assemble this in the garage, which had a height of 11 feet. Various sources put the Queen's height at 14 or 15 feet. But in the movie she fits into the elevator that's only about 8 feet tall, so I figured as long as her torso wasn't upturned and her head was parallel to the floor, she'd fit.
STEP 2: Materials and Cost
Foam boards, which form the basis of the model, have been a staple of many of my recent projects. They're light-weight, strong, smooth, and easier to work with than cardboard, though not as cheap. But they can be cheap; they recently started showing up at Dollar Tree (for $1, as compared to $3 at craft stores). Wal-Mart was great for glue, tape, and spray paint. Lowe's was good for PVC pieces. Other parts were found at craft stores or online. A rough budget estimate on the materials of the statue:
Plaster Strips - $60
Foam Boards - $42
PVC Pipe - $20
Spray Paint - $15
Hot Glue Sticks, Mod Podge, Wooden Dowels, Water Noodles - $28
A grand total of about $165. All things considered, pretty modest for something of this scale. I'd first found plaster strips at craft stores, but when I started needing them in large amounts, I turned to Amazon.com, which had the best deal on a bulk package of plaster strips.
Foam Boards - $42
PVC Pipe - $20
Spray Paint - $15
STEP 3: Making the Skeleton/Frame
Lots of measuring reference and scaling up, tracing outlines of shapes, and cutting them out with a utility knife and hot-gluing pieces together. That's essentially how the skeleton/frame comes together. I'd start with a main profile piece for the section I was tracing, and then fill it out on either side to give the shape of the frame. This whole process is best exhibited in the pictures below.
STEP 4: Teeth and Tail, and Other Details
The tail was made starting with two water noodles. They were light and about the right size and shape. I added a wooden dowel to one end that would be able to slide into a slot in the back of the torso. I covered the noodles with an initial layer of plaster strips and then added foam board pieces for the spines. There were 44 spines altogether, and I had to insert 3 pieces of foam board for each (one on top and two on the sides, triangular), so 132 pieces altogether. Then those spines needed to be covered with more plaster to fill out the detail, and then re-plaster the whole thing for even more strength. The spike at the end of the tail was made as a removable piece, allowing me to have a "Bishop-stabbing" action feature. :)
The teeth were a particular challenge due to the fact that they are transparent. I experimented with trying to cast resin in a clay mold, or somehow cast hot glue in a mold, but the end result was never clear or clean enough. But I took another look at the glue sticks, which were clear, and came up with a solution: I used a wood-burning tool to melt the glue sticks and shape them into points, and make teeth with them that way. They looked good and clear, were relatively cheap, and even had the subtle yellow tint that they should have. These teeth were glued onto a gumline made from air-dry clay, and the whole thing was then glued onto the jaw areas.
The tendons on the jaws were also fun to make. I'd initially planned to make them with plastic wrap, but they didn't look right. I then thought about wax paper instead, and that looked better (still good and semi-transparent), but it didn't have the right texture, so I added some hot glue onto the wax paper and smoothed it out to make it look "stretchy".
STEP 5: Plastering and Finishing Pieces
Once the skeleton/frame pieces were done, they were ready for plaster. I cut the plaster strips into various lengths, and then dipped them in water, and added them on. I would normally double-layer a statue like this, but due to the size I needed to conserve where I could. The legs, however, did get double-layered for added strength.
To smooth it all out, after putting the strips on, I took some plaster (of Paris) and mixed it with water to a milky consistency. I could then paint this on top of the surface to cover any small holes that the strips had, smoothing out the surface. To make the surface shiny and glossy (like the Queen needed to be), I took some Mod Podge and mixed it with a little bit of water and painted a layer of that over the top. And after that, I even sprayed some clear lacquer on top for added strength and shine.
Painting was easy enough. Lots of black, which could usually be found for $1 a can. Which was a good thing, because it took 12 cans to cover the whole thing. After that, a few highlights of yellow on the neck and shoulder areas, and then highlights with blue on raised areas. Those blue highlights help a lot as to how well it photographs.
STEP 6: Some Assembly Required
In order for this thing to be able to be assembled in the garage, parts had to be in separate pieces that could fit together. The whole thing was in 15 pieces: the torso/head, the tail, the arms, the smaller arms, the legs, the 6 back spines, and the inner mouth. As previously explained, the spines attach onto the back with the help of wooden skewers that align with holes. The inner mouth had a rod out the back end that would slide into a hole in the back of the neck. The large arms were done in a similar fashion: a wooden dowel at the top to fit into a piece of PVC pipe on the torso. The smaller arms were simply extended on the base end and that end slid into round openings in the torso. The tail would fit into a hole on the back of the torso. The legs had pieces of PVC pipe on them that would slide onto wooden dowels on the torso. The legs specifically needed to be strong and not rotate, so I had to make them slide onto 2 wooden dowels instead of just one like the arms.
Then I needed a stand to go under the neck to support the front side. I made one out of PVC pipe. I put strips of duct tape across the top where the neck would be able to gently sit on top of.
The feet also needed to sit on the ground more solidly, since her feet were so small. I hot-glued some wooden boards onto the bottom of the feet to make them stronger.
STEP 7: Final Assembly
Setting it up required two people. The torso/head had to be lifted up and onto the neck stand. One person would then support the back of the torso while I added the legs. After that, it was free standing and I could add the arms, legs, spines, tail, and inner mouth. The tail would need a little extra support, so it was sitting on some buckets on a footstool.
The whole thing weighs in at about 50 pounds, which for the size isn't bad. The torso/head piece was 25 pounds in itself, then 6 pounds for each leg, and the rest of the weight in the other pieces. It stood about 10 feet tall and 13 feet long. Full sized, but in a position that did allow it to fit in the 11-foot garage. It was a success!
Well, almost. After it had been standing for a few weeks the duct tape on the neck stand became detached and it became less balanced and I had to take it down. I never got to get pictures of it and my Power Loader both assembled at the same time. :( But after I repair the neck stand, there may be another chance for that in the future.
STEP 8: Final Thoughts and Advice
I'm probably the only person who can claim that they've made a full-sized functional Power Loader and a full-sized Alien Queen. That's why I call myself a geek.
The size and scale of the project was a nice accomplishment, but it was also satisfying to have put that much detail into the "sculpt". I didn't skimp on the detail just because it was huge; rather it allowed me to add details more easily. It was definitely a good step up for what quality I could achieve in my creations.
For making a similar project, or using methods like the one I used, these are the main bits of advice and warnings of potential problems:
This is a video that goes over a lot of the same things explained in this Instructable:
- For large quantities of plaster strips, ordering online will help a lot in keeping a modest budget.
- Foam boards are indispensable. Useful for many, many things.
- To smooth out something covered with plaster strips, mix some plaster (of Paris) with water to a milky consistency and paint over the top. Joint compound would be another good option for smoothing. You can also use sandpaper to smooth further if you wish.
- Make sure stands are strong and weight is well supported, especially for something like this that would take a lot of damage from a fall.
- When attaching a PVC pipe or dowel to somewhere where it will take the burden of weight, it needs to be on VERY securely. Don't be afraid to add extra pieces of foam board and hot-glue the crap out of it to make it stable.
- Get tons of reference photos, and make sure they are accurate to the original creation you are trying to replicate.
- Adding the smaller details that people won't even notice is a good exercise. You get to figure out why these details exist and how important it is to translate them. It's fun to study these designs and see what makes them so unique.
20 Comments
tnikki777 3 years ago
MakeItWithJason 10 years ago
black hole 11 years ago
sutek 12 years ago
GTAtomten 12 years ago
Greetings from sweden :)
cheesyrhino 13 years ago
scoochmaroo 13 years ago
Icalasari 13 years ago
Aprone 13 years ago
justinlamoureux 13 years ago
Aprone 13 years ago
MacGyver1138 13 years ago
Too bad you didn't have a way to make her outside. The queen looks like she wants to stretch her legs!
Kaiven 13 years ago
jeff-o 13 years ago
D00M99 13 years ago
rickym 13 years ago
Kiteman 13 years ago
Just one thing lets it down, IMO. That scaffolding tower under its neck.
Wouldn't thin wires to the ceiling be better (ie less visible)? Or maybe raise the claws (of the next one you make!) so they hold on to the ceiling somehow...?
That's a minor quibble, though, and doesn't get in the way of its awesomositiness.
alexthemoviegeek 13 years ago
Owlbear 13 years ago
