Liftable / Stand-up / Rising - Desk / Table
Intro: Liftable / Stand-up / Rising - Desk / Table
Machanical solution that can be mounted on almost any table & can lift easily high load.
Total costs of this project were cost of table itself + about 150$ in components.
Necessary components:
1. Any cheap bearings x 24
2. Any kind of thick plywood (about 2cm thick)
3. Any Furniture wheels x 4
5. Bolts with flat heads & nuts x 12
6. Mechanical winch x 1
7. Small Construction wheels for cables x 2
8. Cable mounts/clamps x 4
9. Cable x 1 (came with winch)
10. Small construction hooks x 2
11. Strengthening elements like metal corners on top of table base x 4
12. Strengthening elements on bottom part of table sides, 90* metal corners x 4, wooden pins or other imporvisations
13. Screws (various 1cm - 3.5cm)
14. 90* metal corners for top of table x 2
Necessary tools:
1. Drill in a diameter of bearings
2. Drill in a diameter of bolts
3. Small drill for screws
4. Electrical drilling machine
5. Screwdrivers
6. Saw
7. Measuring tools - pencils, angles, rulers, tape measurer, leveling tool
8. Wire cutter or something you can use for it
9. Pliers
Demos:
If you consider such project you should know that it is very importnat to lower construction on both sides of table to make it work, otherwise because of too small angles of the crosses you will brake construction when you will try to lift it. (I will post previous experiments where we broke the table). The larger initial angle of cross will be the easier it will be to rise the table top. In our case our Oak table top weighs about 40kg!
Another important thing to remember is to use construction wheels to reduce friction on cable in the corners ( do not use simple hooks if your table top weighs a lot).
You should also choose thick cable, to avoid stretching of cable in longer shoulder (if you use thin cable longer cable will stretch more & it will rise faster).
It is also important to strengthen base of table as much as you can, because forces on corners will try to bend it (our construction is solid without deformations for 2 months now )
Necessary tools:
5. Screwdrivers
6. Saw
9. Pliers
Demos:
30 Comments
ScarlettKitsune 3 years ago
evalds 3 years ago
The mechanical one is still working fine at my old office :)
pourio 9 years ago
This is pretty awesome. I downloaded the PDF but couldn't find any step-by-step instruction for this. It'd be great if that could be posted, or at least a schematic for me to look and duplicate. Thanks!
coretj 11 years ago
evalds 11 years ago
PinkCrusader 10 years ago
It is April. Will you still be making another one with step by step? If so I will be waiting!
bendotcc 10 years ago
Can you please elaborate on the 24 cheap bearings? What's the purpose for them (I'm guessing to make the scissor motion smoother, less friction)? Where can you find them? What size are they? What's the diameter of the holes? How do you insert or pack the bearings in?
Kind regards.
evalds 10 years ago
sckoobs 10 years ago
evalds 10 years ago
nzrules 10 years ago
bit ugly, but brilliant :-)
Richard
CobyUnger 11 years ago
evalds 11 years ago
LynxSys 11 years ago
aebe 11 years ago
MrNickBarker 11 years ago
Also I should mention that the table is a bit too low for you. Your elbows should be at almast 90 degrees in standing position and the top of the screen should be at eye level.
evalds 11 years ago
Since the back part of the top is resting on wheels is it possible that if you lean on the table that the back lifts and everything slides towards you?
My proposed solution was to use a slider, but I don't know if it's necessary.
evalds 11 years ago
evalds 11 years ago
