Introduction: Light Box (ariel Moreno)
This project is going to be about my light box that i am making there is many materials that are used in this project and we will get to those in a sec . A light box can be helpful in many ways such as holding accessibility's . With this being said a light box can be difficult but easy to make in the process . The light box app that i use is a app called tinker cad , the app tinker cad is a app where u can 3D print and engrave shapes . This app is very helpful and probably one of the most easiest app to 3D print or engrave shapes .
Step 1: Materials and Equipment
-3D filament
-acrylic
-ruler
3D printing filament is the thermoplastic feed-stock for fused deposition modeling 3D printers.
Acrylic you will need for your design on your light box
Ruler you will need to make sure everything is measured correctly and lengthened right
Step 2: Cutting and Engraving Acrylic
first picture shown here is a design i created on my light box. How do you make this ?
1. You are going to go to google draw
2. Go on to the interment and look up any design as a stencil (example: pattern stencil)
3. paste it on google draw
4. trace it (make sure you are not using line because it wont fill in correctly)
Second picture shown here is a circuit diagram. How do you make this?
1. go to a cite that is called circuit diagram
2. on the left side there is materials that you will be putting together to make this circuit diagram
3. in the picture above get those materials and put them on the diagram to make your circuit diagram
Step 3: Designing and Printing the Box
first picture above i'm going to show you how to start making your light box using the app called TINKER CAD
1. grab a box with the materials shown on the right
2. click on the box and put your and put your dimensions as x:120 y:40 and your z:31.5
3.next you are going to grab a whole box and put it in the right side and put the dimensions x: 13.50 y:15
4. next grab a sphere whole and rotate it 90 degrees and x at 30 and y at 3
After done with all that and it should look like my 4th picture shown above
Step 4: Electronics and Wiring
After done with 3D printing you are going to sorter it
after sotering you will need to get your led light strip and your wire and connect it to your design to make the glass glow
