Introduction: Light Sensing Fairy Lights
This is a set of lights that smoothly changes colour and pattern depending on the amount of light in the room.
Apologies for the video - you'll need to view it in HD, and even then you may not be able top make out all of the code.
You'll need:
I connected:
There's more information on controlling and wiring up the lights on the Espruino tutorial for WS2811s. The actual code you need to copy and paste in is:
function onInit() {
SPI1.setup({baud:3200000, mosi:A7});
C3.set(); // Pull the light sensor's potential divider up to 3.3v
onInit();
var light = 0.0; // an average
function getPattern() {
var lightInstant = analogRead(C1)*3;
light = lightInstant*0.1 + light*0.9;
var cols = [];
for (var i=0;i<50;i++) {
var c = (-Math.abs(i-25)*10) + light*1024 - 200;
if (c<0) c=0;
if (c>255) c=255;
cols.push(c);
c = (-Math.abs(i-25)*10) + light*1024 - 450;
if (c<0) c=0;
if (c>255) c=255;
cols.push(c);
c = (-Math.abs(i-25)*10) + light*1024 - 600;
if (c<0) c=0;
if (c>255) c=255;
cols.push(c);
return cols;
function doLights() {
SPI1.send4bit(getPattern(), 0b0001, 0b0011);
setInterval(doLights, 50);
And job done! If you type 'save()' it'll keep working even after power off.
You'll need:
- An STM32F4DISCOVERY board
- A USB-TTL converter - this is not vital, without it the LEDs will flicker when USB is plugged in, but once you remove it they will be fine
- A WS2811 LED string
- A Light Dependent Resistor (LDR) and matching normal resistor (in my case 200k)
- The Espruino JavaScript interpreter Software
I connected:
- The white+red wires of the WS2811s to 0v and 5v
- The green wire of the LDR to pin PA7
- The LDR between ground and pin PC1
- A 200kOhm resistor between PC3 and PC1
function onInit() {
onInit();
var cols = [];
if (c<0) c=0;
if (c>255) c=255;
cols.push(c);
if (c<0) c=0;
if (c>255) c=255;
cols.push(c);
if (c<0) c=0;
if (c>255) c=255;
cols.push(c);
return cols;
