Light Studio for Photographers (Tabletop)
Intro: Light Studio for Photographers (Tabletop)
This instructable shows you the easy, inexpensive, and quick way to create a light box that can get you the same photographic results as a 150 dollar light box. The only difference is that this one can ultimately be built for under 10 dollars. For those of you out there that don't mind spending a few extra bucks or for some reason hate recycling, you can spend up to 30, but hey, its still cheap and way less than those "official" light box rip offs.
STEP 1: Get Materials
Refer to the image for materials.
Keep in mind what you may plan to shoot pictures of, for it will be a good factor in deciding how big you want your box to be. Since were laying poster board in the box, I would recommend that you keep the boxes' dimensions within the width of the poster board. The two colors of poster board I would recommend getting are white and black, but of course its also good to experiment and I find that blue and red also make good backgrounds. But, use any colors you wish. The color of the poster board sets the "mood" for the picture i.e. black background would be for like sleek watches or high dollar items, where as white may be for something like a vase with flowers, or something "light" and "airy"
STEP 2: Prep the Box
The first thing you will need to do is get the box ready so you can apply the screen windows (vinyl shower curtain in my case)
You only assemble the bottom of the box, leave the top of the box flaps open, but make sure the bottom is taped shut. Try to tape the flaps together very closely to avoid a lot of light to get through.
Now lay the box on its side and assuming your box is square the side that is now facing up is your new top. This is how the box will be oriented from now on, whenever you take photographs.
Make sure the open end is towards you and cut the top and bottom flaps off of the box, but make sure you leave the left and right flaps.
Now (I used a carpenters square but I assume most people don't have a 3 foot square laying around, basically all you need is a straight edge. Get your marker and trace straight lines parallel to all edges creating a square shape on each side of the box, left, right, top and bottom. Make sure to leave about 2 inches of space between your lines and the edge of the box. If you have a larger box, I would go with 3 or more inches. Use your judgment on this one. Now if it helps, keep using your straight edge (whatever you may have used) and use it to aid you in using the utility knife to cut the squares out of each side of the box. Be sure to leave the former bottom now currently the back of the box taped up. Don't cut the back of the box that you taped up.
The picture should clear any questions you may have up. Areas in gray are the sections of the box that are to be eliminated.
STEP 3: Cut and Apply Light Diffusing Material to Box Windows
This step involves cutting your material, in my case a vinyl shower curtain to fit the open spaces on the sides of the box.
Get your measuring tape or w/e you have and measure the square spaces in the sides of your box to get an idea of how big to cut your squares of material. Going past the edge is key here, in case you may not have realized that. So if your square space is 18 inches by 18 inches then you want your square piece of material to be 20 or 21 inches.
The look of the box isn't important, so going over the edge and doing a crappy tape job isn't the end of the world. You can still make it look neat if you tape the material on from the inside of the box. You could also glue it if that floats your boat. The 2 or more inches of space you left at the edges is where you will attach the light diffusing material to, whether you do it from the inside of the box or outside of the box. As you can see I just taped mine on the outside with duct tape. Look at the image notes.
The bottom of the box does not need covered with the light diffusing material, leave the hole..as a hole. The poster board will be covering the bottom anyway.
Note: Try to keep your material tight or "stretched" so to speak so its not all saggy or droopy in effort not to cause serious shadows or detectable light distortion....creases aren't a big deal as you can see my shower curtain has creases in it and I have found no effects in my photos.
STEP 4: Buying Poster Board and Lights
Now your box is basically done. All that we need now are light sources and backdrops. You can use anything as a backdrop if you are one of those creative types and can make it work. I find that poster board works very well. The thing to make sure is that the intersection of the bottom and back of box is underneath the curved portion of your backdrop. This is crucial in order to create a photo without having a crease revealed, and rather makes an illusion of having an infinite nothingness behind your subject.
The more gradual the curve of the backdrop, the less immediate gradient of shadow. It just takes some experimenting, but you will find that it works fine the first time you try it.
You can use lamps that you already have or buy new ones from Walmart or something.
Refer to the image notes for more information.
STEP 5: Setting Up Lighting
Now that you have everything done you are ready to take some photos. The only thing you may want to do now is learn more about lighting and still life photography. Arranging the lights and angles can drastically change the effects or mood of your photos, along with other various factors. There are other articles and tutorials that go in depth about still life photography and studio shooting that you can look into, I figured you would get more professional advice by searching Google than me mushing a few things here and there in with this instructable.
I hope you enjoyed this instructable, it was my first one. Please let me know if you have any suggestions, or any questions that I may have left unclear.
Just email me millertime07MSU@gmail.com and include instructable or something along those lines in the subject so I can differentiate from spam and your emails.
Also, I only briefly proofread my sentences please let me know if something does not make sense or needs revised.
Thank you,
- T
Thank you,
- T
21 Comments
lrieger 9 years ago
Haven't made it yet, but the instructions seem very straight forward. Thanks!
tperlow 9 years ago
So awesome! Thx!!! :D
ktripp 10 years ago
Thank you for your assistance! Came out great! Now I need a bigger lightbox to take a pictrue of the lightbox ;)
glara2 10 years ago
Excellent instructable. I like the idea of re purposing a box, as some of them can be folded without being damaged, so this is lightweight and portable. I would suggest to stick the diffusing material from the inside, or paint it white. This is to avoid weird lines on shiny round objects.
suayres 12 years ago
AXracer 13 years ago
ammar103 14 years ago
wdiosa 14 years ago
grandma3 15 years ago
walrus13 15 years ago
Ray Makes Stuff 15 years ago
djsc 15 years ago
gedden 16 years ago
jobel602 16 years ago
killerjackalope 16 years ago
michaelbak 16 years ago
dmlandrum 16 years ago
http://flickr.com/photos/dmlandrum/sets/72157602019838167/
I'm very pleased with the results. Getting the exposures right took some trial and error, but it was well worth it. Now I want to build a stouter version using Masonite.
ryzellon 16 years ago
millertime07MS 16 years ago
Brennn10 16 years ago
