Introduction: Light Up Floral Monogram Letter
Check out the video to familiarise yourself with the process!
Wooden fillable letter
Paint
Faux foam flowers
Wired string lights - battery operated
Paint brush
Glue gun and glue
Super glue
Drill
Step 1: Paint
Paint your fillable letter - I chose black to contrast the flowers and the lights!
Step 2: Arrange Flowers
Arange your flowers, as you can see I used large roses and then smaller ones inbetween.
Once you're happy with the arrangement use a glue gun or other glue to stick the flowers in place.
Step 3: Lighting
Turn your wooden letter over and make a small hole with a drill or similar big enough for your wired string fairy lights to fit through.
Pull your lights all the way through and then glue down the battery pack, making sure the battery cover and switch are facing ouwards so they can be replaced and you're able to turn it on and off.
Step 4: Arrange Lights
Wrap the wire, of the wired string fairy lights, around the flowers starting from the bottom where the hole is, until you get to the top!
Step 5: Finish!
Your light up floral monogram is now complete!
