Light Up Pop Up Card
Intro: Light Up Pop Up Card
Ever need to create an impressive homemade card for someone special? With as little as two hours, create something priceless for that special someone. This pop up card is easy to make and will have an impressive impact on your audience.
The card is from an instructable that I got from kate12345. Here's the link: https://www.instructables.com/id/Pixelated-popup-card/
The flowers were created using katmataz's instruction: https://www.instructables.com/id/Origami-Paper-Corsage/
The leaf is from Muhaiminah Faiz: https://www.instructables.com/id/Origami-leaf/
The rest was created as a result of a brain spark and here are the results.
STEP 1: Materials
Paper
Cardstock
Cardboard
Small sheet of Foam
Scissors
Hot Glue
RGB LED - depends on which setup you use: a premade LED w/ Switch or your own version*
Origami Paper (assortment of colors)
Razor Blade
Pen
Sharpies
Electrical Tape
*If you do your own version, you will need the materials found in this instructable: https://www.instructables.com/id/Light-up-Christmas-Card/
Cardstock
Cardboard
Small sheet of Foam
Scissors
Hot Glue
Razor Blade
Pen
Sharpies
Electrical Tape
STEP 2: Flowers & Heart
Following the instructions from the other instructables, create the heart and flowers.
Then, take a blank card paste the heart on the inside. Take the flowers and hot glue it on the outside where you see fit.
After doing so, it is time to install the LEDs. There are two ways you can do it. The easy way is to buy a RGB LED with a switch already installed. That way, you do not need to do any complex wiring. Once the switch is turned, the light will turn on. Drawbacks with this are that the light doesn't turn on when the card is opened.
The more complex way is to follow this instrucable: https://www.instructables.com/id/Light-up-Christmas-Card/ On this design, the light turns on when the card is opened.
Setting up the LED position is the same in both however. First, I cut a piece of soft white foam in a way that the LED would be able to pass the most light through the pixelations to create a ray pattern. (Before doing so, cut out an area under the Heart so the light can fit through.) After doing so, hot glue the LED in place on the foam. Take the foam and mount it on a piece of cardboard that is the same dimensions as the card. Then, mount that cardboard attachment onto the card itself.
STEP 3: Assembling the Card
After attaching the foam, LED, and cardboard together, mount that assembly onto the card. (Use glue to hold it in place.)
Then, use electrical tape to cover up the bottom and side areas that are exposed so that you have a nice trim.
You are now done. Enjoy your creation and give it to someone special!
5 Comments
帥官 9 years ago
完美
Vignesh_Rao 10 years ago
AJ_Smoothie 10 years ago
jeffmazter406 10 years ago
