Introduction: Light Up Skull
items needed:
Equipment
- soldering iron
- solder
- wire cutters
- safety glasses
- solder cleaner
Materials
- Flashing LED Kit $3 at frys.com
- Jumper Wires $5 for 40 on amazon.com
- battery holder $5 for 3 on amazon.com
- manual for the kit pdf (also comes with the kit)
- lithium coin batteries$6 for 20 on amazon.com
- Halloween skull decor
Step 1: Solder Parts Onto Board
Start the kit, follow the manual. Put the pieces together by following the manualDo not do steps 5 and 6
Step 2: Soldering Led Wires
Then once finished with steps 1 through 4 solder the wires to the board that will be your led and solder the battery holder. Depending what skull you have you might have a skull that already comes with the led or not. So you might have to solder new led lights onto your board or solder the ones that already come in your skull. When all done solder the battery holder by following the instructions.
Step 3: Add Led Into Skull
Make any changes to the skull to accommodate your led lights; then fit everything together, glue and cutters may be needed to make a hole to put the board and battery holder in skull and glue the led's into the skull to get it to light up. Feel free to make any changes etc. to the skull to get the desired look you want!
Then you will be all done!
Step 4: All Done!
This is the final product. Here is a video of the Skull all lit up https://www.youtube.com/watch?v=chQGYg_zPUU
