Introduction: Light Follower Robot Using Arduino
The circuit is used to control a robot by increasing or reducing the light intensity.circuit components are,
potential meter,arduino uno,operational amplifier, npn darlington transistor, motor,Ldr-light dependent resistor,
Step 1:
Step 2: Working
when the intensity of light to the ldr is increased current flows to the amplifier then to the arduino.This causes the motor to rotate,.The motor rotates the wheels of the robot
Step 3: Code
int in=13;
int out=12;
int pinState=0;
void setup() {
pinMode(in,INPUT);
pinMode(out,OUTPUT); // put your setup code here, to run once:
void loop() {
pinState=digitalRead(in);
if(pinState==HIGH)
{ digitalWrite(out,HIGH);
} else
{ digitalWrite(out,LOW);
} // put your main code here, to run repeatedly:
