Introduction: Light Seeking Robot ATLAS_15
Hey guys this is my first instructable,in wich i'll teach you how to make a light seeking robot.This is a project i've made ,because i like robotics, and i'm starting with it, so it's a simple way to build a robot.I've made it with very cheap materials, but if you want you can make it better ,i'm planning to make a radiocontrolled one , but i dont know anything about it .
Let's get started !!!....
Step 1: Part List and Materials
For this instructable you'll need :
2 Plastic circles , i used circles but you can use any shape
3 big screws and bolts
Hot glue and hot glue gun
Cables (1,5 meters aprox.)
2 Dvd 5.9 Volts Motors
2 TIP120 Transistor
2 1k Resistors
2 1N4001 Diodes
2 LDRs
1 breadboard (optional , i didn't use it ,but it make a more structured project)
2 Wheels ( i got them from an old toy )
1 Switch
To power up this project i'll be using a 9 volt battery , but you can also use a A23 12 volt battery or any other similar power source ,you'll also need sodering tools such a sodering iron stanium , helping hands ,etc.
2 TIP120 Transistor
2 1k Resistors
2 1N4001 Diodes
2 LDRs
1 Switch
Step 2: Circuit and Internal Structure
This is the diagram of the circuit i used . be carefull off the polarity of the motors and the position of the LDRs , because that defines the moves that the robot does .Before you proced to the next step , make sure that the motors spin in a correct way .There are no sodering instructions less than these , so you are free to make it in your way!!
Step 3: Creating the Body
To make the body i used 2 old plastic circles , and i attached it with screws and bolts as it's show down there , but you can make the body you want , you could also use and od tupper .
Step 4: Glue It Up
So now we are at the fun step , i glued the circuit to the body with the hot glue gun , i also added the wheels to the motors using it .I glued the LDRs to the top circle of the body , as it's showed in the image below .After you glued everything you'll have to put on the bolts to close the body of the robot ....
Step 5: Finish !!!!
Now you are done !!! You've made a light seeking robot !!!!
I leave more images to show you more of my robot ,stay hungry stay foolish ....
![[Insert Robot Name Here] the Matlab Robot](https://content.instructables.com/FSL/SUO8/IVO4PU5Y/FSLSUO8IVO4PU5Y.jpg?auto=webp&crop=1%3A1&frame=1&width=130)
