Introduction: Light Up a Xbox Controller With LEDs
This instructable sets out to light up the four A,B,X,Y buttons and jewel of an original Xbox Controller-S.
To complete this project, being comfortable with a soldering iron is recommended. Even if you are not experienced in soldering but would like to learn, read up on these guides and feel free to do this mod.
How to Solder
How to Wire LEDs
This guide teaches with words as well as pictures, almost all of which have comments to help clarify what is going on during the install.
This can be a tedious install, as tolerances inside of a Xbox controller are relatively tight, the pieces are small, and expect each controller to take anywhere from 2-3 hours depending on how skilled you are. In this guide I use slow-fading RGB (Red, Green, Blue) LEDs, though any combination of colors can be used for your lighting choice.
I hope you enjoy this instructable, and are able to modify your Xbox controller to light up many nights of gaming.
*** I am not liable for any personal damage or injury that occurs from following this tutorial. You will be working with electricity (Very low voltage) and hot tools (soldering iron & hot glue gun). If you destroy your controller you will just have to spend $10 on a new one ***
Step 1: Getting the Supplies
The tools needed are:
3mm LEDs - There are quite a few options for color selection. White for all four buttons. Red, Green, Blue, and Yellow: one color per button. All four a single solid color. Or in the case of this instructable: all RGB Slow Fade. The more colors you have, the more difficult it can become to manage the wires as each species of led can require its own voltage, and thus its own resistor. You will also want LEDs of at least 5,000mcd for this project, the brighter the better.
***Purchasing LEDs***
Buying LEDs from retail stores is very expensive with inferior light capacity and quality. Through the internet, namely eBay, you can purchase large amounts of high quality LEDs for extremely low prices. I bought 50x 3mm RGB LEDs for $15 including shipping and tax. Excellent sellers are hktaiyuen, jledhk, and LED HK. After completing this mod multiple times, I now recommend using either 4 white LEDs for the buttons, or if possible, four separate colors, one for each matching colored button (Red, Green, Blue, Yellow/Amber). The slow-fade RGBs become de-synced with time in their color switching, and end up looking ugly due to color opposites canceling out light (red light emitting and being absorbed by its opposite color in the green button for example).
Resistors (Cheap) - This project will require resistors. You will need to calculate the level of resistance needed (in Ohms) based upon how you wire your LEDs to the controller mainboard. As I have four identical LEDs, I have opted for parallel wiring which requires only one resistor. Use ledcalc to determine your solution.
Soldering Iron (15-30 watts, ~$15) - Any cheap heat based soldering iron will do.
Solder ($5) - I recommend silver solder with a rosin core, the silver helps create a strong joint while the rosin helps flow into a clean connection.
Needle nose Pliers ($8) - Used for bending the legs of LEDs and assisting in holding parts.
Wire Clippers ($6) - Used to cut the legs of LEDs, resistors, and lengths of wire.
Electrical Tape ($3) - Protects exposed wires from connecting to anything else in the controller.
Power Drill with Drill Bits - Necessary for creating holes in buttons for LED legs, and shaping the controller casing to fit the modified buttons.
Hot Glue Gun and Sticks ($10)- Used to electrically insulate connections and keep parts from moving around. Works great for small electronics as it doesn't conduct electricity.
Wire - This depends on preference. For this guide I used 30 AWG (extremely fine) wire purchased from the llamma store. Looking back now (Jan 2009), and having experience with using these controllers and the wires snapping, and having to reinstall them, I now recommend using 22-24 AWG wire. As a bonus, 24 AWG wire is easily found in the common ethernet cable. Since not much is needed for a single controller, you can simply cut off the sheathing of any CAT5e and take out the insides; the wires are far more durable than 30AWG.
Step 2: Disassembling the Controller
The Xbox Controller-S is designed to be taken apart, and is easily opened with a regular small-sized Philips screwdriver. There are 7 screws on the controller casing, three on each side, and one underneath the middle sticker, removing this sticker voids the controller warranty, though if you're about to mod it it doesn't matter anyway.
Screws are highlighted in picture below, either tear off the middle sticker or use an Xacto knife to cut around the hole (you can feel it with your finger).
Remove the bottom shell and place it to the side. After that, slide the rumble motor adapters off of the mainboard, they are fragile and you can tear out the wires by pulling on them, grab the connector itself. If you accidentally tear out a wire, you can always solder it back on.
Lift out the mainboard and remove the button cover over the A, B, X, Y, White, and Black buttons.
Remove the buttons and its time to do some surgery.
Step 3: Drilling the Buttons
Information:
Before you drill, view the picture below to see the direction the holes should face. This is the optimal layout for the LED legs and will prevent wires from getting tangled.
Each button will have two holes drilled into the side of it for each leg of your LED. Use the smallest drill bit you have and space out the holes to prevent the legs from touching one another. If the legs end up touching one another, the LED will not turn on.
In the center of each button there are four pillars, and attached to each of those is a thin plate of plastic (see secondary photos). Our goal is to remove these plates and make room for a LED to fit inside of the button. Your LED and wiring should remain below the four pillars, as these are what press the button down. Do not drill too far down as you can damage the base of the button where the letter is located, and possibly crack the letter.
Drilling
Select a drill bit about the width of your 3mm LED and drill straight down into the button and remove the four plates. After having drilled the button there will be many shavings inside that prevent light from glowing through the button, clean it by blowing into it and scrape out chunks with a small tool (I used my smallest drill bit).
Repeat for all four buttons according to their direction in the picture below.
Step 4: Attaching the LED
With the center of the button properly drilled out, it is time to install the LED into the button housing.
Stick your LED into the button, and eyeball the distance from the base of the LED to the top of the four pillars. Bend your LED legs below this distance at a sharp angle, and place the legs through the two holes. To keep things simple, always have the positive leg of the leg facing towards the top of the controller (view the button letter to see the correct orientation).
You will have to push, bend, and squeeze the led into the button, and once the LED base is in the center of the button, jam it into the bottom of the button with a small tool or one end of your needle nose pliers. The wires and LED should be past the pillars which will prevent accidental presses.
Testing
If you have a 3v button cell battery test to make sure the LED turns on. When you are confident it works, stick the nozzle of the hot glue gun into the button and pull the trigger, locking the LED and its legs in place. But be sure not to get glue on top of the pillars.
Step 5: Milling Out the Casing
The legs for our LEDs were not designed for the controller, and prevent them going into their respective slots. We will be using a power drill and a large bit to remove the casing that gets in the way of the legs.
Just try to place a button in its respective slot, and remove any casing where the legs would go. Press the drill bit sideways against the casing to remove plastic. The button should be able to rest in its slot without the legs touching any part of the casing or impeding its movement. If you have a pair of wire cutters it can help to cut the casing after drilling. Repeat for all four buttons, the pictures below should help.
Step 6: Wiring the LEDs
Now comes the difficult part, soldering the wires to their respective legs on the LEDs.
Each LED has a positive and negative leg, and as such different colors will help. I used a corresponding colored wire for each button, and all negative legs are black. As this is for a parallel install, all positive wires will be soldered together, as will all negatives.
Cut a length of wire for the positive leg of your LED, 4-5 inches should be enough. Then with a knife or wire strippers remove the sheathing on both ends of the wire. It is time to tin our wire and LED. Tinning is the process of applying solder to each piece that will be connected together. After having stripped the wire, add solder to the exposed core and add solder to the leg of the LED. Then you can solder the wire and leg together without requiring three hands.
Now do the same for all negative legs of the LEDs, preferably using a black wire to designate it is negative. Hold the wires at the base of the LED together, and carefully twist the positive and negative wires together, this will let us have control over where our wires go. After all negative wires have been attached, solder the four negative ends together, as well as the four positive ends together.
Testing You can touch the positive bundle and negative bundle to a button cell battery to see if all of the connections are solid.
Step 7: The Resistor
A resistor is used to lower the amount of current from a source of electricity into a level usable by the LEDs. You will need to use ledcalc to know what resistor you need for your setup. Different color LEDs can have different voltages. Some reds are 2.0 volts, some blues are 3.4v. If you use the same resistor for four different colored LEDs, some will be bright and others dim. If you can get all of the LEDs to have the same power requirements, great.
The best source for power in an Xbox Controller is the red 5v power source. My RGB LEDs require 3.4v and 25mA each. Parallel is used to minimize the amount of wires and resistors needed for an install, by placing more work on a single resistor (Meaning we need a higher maximum wattage rating for the resistor, but in the case of 5 LEDs it doesn't really matter). You can also use series for wiring, or each LED receiving its own resistor.
For my install, I required an 18 Ohm, 1/4 Wattage resistor as told by ledcalc (This is for a 5v supply, four 3.4v 25mA LEDs in parallel). The wattage rating is the maximum amount of heat the resistor can give off, you can have a far higher rating than required and still be fine, just don't overload the resistor.
The Power Source
If you look at where the controller cable attached to the mainboard, you will see many colored wires. Find the red wire (which should be at the bottom) and follow the pin to the other side. We will solder our resistor to this solder point.
With the needle nose pliers bend your resistor into shape, tin the end of it, and attach it to the solder point on the mainboard.
Wiring the Wires
As all of the positive wires have been soldered together, cut a large length of wire (6 inches) and solder it to the positive bundle. Mine is colored white, and has been attached to the other end of our resistor.
The black bundle should receive its own wire as well, only it will be wired to the negative solder point where the black wire comes through the mainboard (shown in picture).
Testing
You should now be able to plug the controller into the console, turn it on, and everything should light up!
Step 8: The Jewel (Optional)
At this point, if you are happy with the A, B, X, and Y buttons being lit up, you can hot glue your connections to secure/insulate them (see next page) and put your controller back together. If you are feeling adventurous, we will add a single LED to the jewel.
By no means do you need to use one LED, you can use any combination of lights you wish, but remember that different LEDs may require their own resistor. I chose a single LED as I already had the resistors on hand and it gets the job done.
Removing the Casing
We are going to remove the main casing underneath the Xbox controller jewel in order to let our LED light it up. I'm sure there is a better tool to use than a power drill, but its what I have on hand and has worked fairly well. Drill away into the casing until you hear a change in noise (from hitting the sticker) or see white (the underside of the jewel sticker). Keep removing plastic from the casing until there is a rim along the edge of the jewel. If you pop the jewel out, remove the entire jewel and apply hot glue on the surface of the casing and reattach it.
Another Resistor
Instead of using two separate resistors as I did, if all of your LEDs are identical you could select a resistor that supports five LEDs, instead of my unprepared 4 & 1 method.
I have attached a 68 Ohm resistor to the 5v supply, that supports a single 3.4v 25mA LED. The opposite end of this resistor has been soldered to the positive leg of the jewel LED, and the negative wire of the jewel LED has been attached to the negative bundle. The jewel LED itself has been hot glued to the casing to keep it in place.
You can test the controller to verify all the lights are working.
Step 9: Cleanup
Hopefully all of the lights turn on, the buttons can move relatively freely (it doesn't need to be perfect, as long as they are not firmly held in place, and press down normally it is acceptable), and our controller is ready to be cleaned up and put back together.
Hot glue is a miracle in small electronics, it is an electrical insulator, and you can pour it on where the resistors connect to the 5v supply, and any other exposed area. It will not short-circuit the mainboard and will keep electrical components from bumping into one another - which could prevent the lights from turning on.
Wrap some electrical tape around each wire bundle to prevent a short with anything else in the controller.
Put the controller back together in reverse order, making sure not to pinch (and possibly internally break) any wires (especially where the joysticks go through). Re-attach the rumble motors, align the controller cable into its slot, replace the rear cover, and put all of the screws back into the controller. It should feel just like it used to.
May you enjoy your newly lit Xbox controller and have many nights of gaming in the dark!
If you have any ideas on how to improve this instructable feel free to leave a comment or post what you've discovered. Help make instructables even better by sharing your knowledge.
59 Comments
13 years ago on Introduction
Few quick questions: 1) Are the buttons transparent enough to let a white led shine through, but opaque enough so that it looks like it's lighting up the correct color? 2) On a wireless xbox 360 controller, is it possible to hook up the leds to a power source other than the rumble power? 3) If not, which prong for the rumble power (the prongs on the opposite side of the controller as the rumble adapter) is positive and which is negative?
Thanks,
TpR
Reply 13 years ago on Introduction
Yes, using a white LED will shine through the button itself and take on some of the plastics color. So putting a white LED in a red button will take on red tint, but be more of a very light red (not pink though). For a strong effect, I would recommend one color LED per color button, so red to red, blue for blue, etc.
Yes, you can access power from the 360 controller without using a rumble motor, in fact you should be taking your power from the mainboard. There are five or six solder pins going through the mainboard, they hold the power and you should solder directly to them.
I believe you would be interested in this guide: www.llamma.com/xbox360/mods/xbox%20360%20Controller%20LED%20Mod.htm
I didn't exactly know how to say it, but when I said the rumble power, I meant the prongs on the mainboard that you attach it to to make them 'rumbled activated leds' as the llamma.com guide said. I'm interested in making them lit at all times, is there a power supply on the mainboard I can tap into (excluding the previously mentioned prongs)?
No, that's exactly it, soldering to the mainboard power (directly where the USB cable attaches, which is only for wired controllers) will leave the LEDs lit as long as the controller is on. Soldering to the rumble packs means soldering to the red and black wires that go to the rumblers, in which case they would only light up during vibration being activated.
The llamma guide at the bottom with the rumble activated LED is a completely separate step that is optional.
To access power pins on the wireless controller, you can tap into the play and charge kit/headset connector. Have the controller sitting normally on a table, with the sticks pointing in the air. Looking at the controller the direction you normally hold it, there are 4 pins and a center alignment hole on the base of the controller. Number the pins in your head with the one on the far left being pin 1 and all the way on the right being pin 4. Here are their specs:
Pin 1: Ground, Pin 2: Microphone Receive, Pin 3: Microphone Send, Pin 4: Power 3v.
So quite simply, you can solder your resistors to the 3v power pin, and the negative end of your LEDs to pin 1 (ground). I hope that is what you were wanting. You wouldn't want to tap power from the microphone pins, since they transmit data and can cause problems if you tap into them.
Hate to keep bothering you, but I'm considering getting a four pack of leds. They have a 1200-2000 mcd, is that adequate? And a 100 ohm resistor is needed for a 5 volt supply. Since I'm tapping into the the 3V supply, a) will the leds be bright enough? b) Will a resistor be necessary (parallel wiring)?
*update* The best I've been able to find without buying almost 50 is only 3k mcd.
If you want high brightness, just buy a pack of 50 off eBay, that's just how these things work, as brick-and-mortar stores only like to sell absolute junk. The LED will use the exact same amount of electricity whether your 5mm 3.4v 20mA LED is rated for 1kmcd or 15kmcd, it's all a question of electrical efficiency per LED. 1.2kmcd is pretty dim, you could see it at night with the lights off as a very subtle glow. I'd recommend aiming for 5k-7kmcd. For your suggestion of 3k, I think it would be acceptable. It's all personal preference really.
As far as your resistor, this is where LEDs are awesome. You can have your numbers wrong and they still work, just maybe not at the optimal brightness. Let's say you are using a blue LED, which is rated for 3.4v, yet we only have a 3.0v supply. Indeed, the LED will be underpowered and it's brightness reduced by about 30%. I think the minimum limit for a blue/green LED lighting up is around 2.4v or so (which would be extremely dim), so you're in the clear. LED specs always have a variable rating, something like ~3.2-3.4 volts, feel free to go over or under at your leisure.
If you use a red LED, which is rated for 1.9v, and overvolt it to 3.0v, it will be extremely bright, around 40% brighter. That extra brightness comes at a cost though, the LED will now last only about ~20,000 hours of constantly being on (which is still a ton) than the normal 80,000 hours. The reverse is true as well, undervolting an LED will add more life. Lots of pocket LED flashlights use this trick to the extreme, two 2032 button cell batteries in series (3v * 2 = 6v) for a 3.4v White LED. I personally swapped out the white LED for a red, with an extreme overvolt of 6 volts onto the 1.9v standard red. Granted, it's bad for the LED, but it's a cheap $1 flashlight.
To measure your resistor, go to ledcalc.com, put in your numbers, and find your result. Since we can't go higher than 3.0 volts, I put in 2.9v, and got a 5.6 Ohm 1/8 W resistor. Thats for a single blue/greem LED mind you, but you can figure it out with series or parellel.
It says the LED's voltage norm is 3.0 volts, so is a resistor necessary?
From my experience, you always have to have a resistor, no matter what the juice being given to the LED is. LEDs are current powered, but voltage dependent. Basically, as the voltage increases, so does the current (the mA) to the LED increasing brightness. While your voltage may be fine, a 3v supply for a 2.9v LED, the current will not be regulated. If whereever you are tapping the power from (in this case the microphone power plug) doesn't let the current go over 20mA, then yes you wouldn't need a resistor. I don't have measurements for how much current that pin is running, only the voltage, so I have to tell you to use a resistor or something could fry. Resistor calculations take into account both current and desired voltage. The only exception is button cell batteries, because the way the batteries are made they have current regulation.
Ok. I used ledcalc and I put in a voltage drop of 2.9v, a supply voltage of 3v, 4 LEDs and for 15 mA it said a 6.8 ohm, and for 20mA it said 5.6 ohm, that sound about right?
Stick with 20mA rather than 15mA, you aren't facing severe power requirements, and dropping the current that low makes the LEDs far less bright.
I believe you used the default ledcalc.com Guru to calculate your resistor, which in most cases is fine. There are three other options, single, series, and parallel wiring. I recommend using parallel for this install, since only a single resistor is needed, which becomes very important inside of a cramped Xbox controller. Note that using parallel requires all your LEDs be the same type (white 2.9v draw for example). Using different colors like red,green,blue, and yellow would each require their own resistor. Note that green/blue/white LEDS are all 2.9v (minimum, at optimal they are 3.4v, but that isn't possible in this install due to the 3.0v source), and red/amber LEDs are both 1.9v, meaning these color pairs could be in parallel, making for a total of two resistors.
Calculating a 3.0v source, with 2.9 draw @ 20mA and four LEDs wired in parallel makes for a single 1.5 Ohm 1/8W resistor in the case of four blue/green/white.
The resistor I found in 1.5 ohms, but 1W.
I searched "1.5 ohm" on eBay, and found a 100x pack of 1.5 ohm 1/4 W resistors in less than 10 seconds for a total cost including shipping $2.50.
Wattage rating is only a minimum, you could power a LED with a 5 W rated resistor, which would be excessively large. The wattage rating means how much electricity can be converted to heat before the resistor fails (read: melts). Just never go lower than the ohm rating require, and I don't think common resistors are made below 1/8W, so you're fine.
14 years ago on Introduction
Would this work on an xbox 360 controller? I haven't opened it up yet, but im wondering if anyone knows where i can get the power source from? I'm about to open mine up now and i'll let you know how it goes
Reply 14 years ago on Introduction
The process is practically identical for a 360 controller. Flood the existing LEDs (add solder), touch back and forth between the two connections until the LED floats away and you can pick it off. Positives are marked by white paint on one side of the LED, so player 1's positive terminal would have a D1 or white dot close to it. Look up llamma's guide for modding a 360 controller for help.
Ok cool thank you. I need to go buy a T8H as my current one wont fit so I wasn't able to open it up.
You can either buy a legitimate T8H torx screwdriver (I would suggest from llamma.org), or you can do what us modders had to do the day the 360 came out. We took an awl or very small chisel, and smashed it with a hammer onto the center pin. If you do it correctly the center pin will break off, and a normal T8 driver will unscrew it. Saves you $20 (minimum) and a week of shipping.
Ah, thats not the problem. Problem is that I have bits, not drivers. So it wont fit in 4 of the holes. :~(
I bought my T8H from amazon.com for $2.99+$5.00 shipping. It's a small screwdriver and the handle's comfort leaves alot to be desired, but it gets the job done.
If you didn't want to buy a T8H, you could just open it the old fashioned way, back when the 360 first came out and nobody knew what a T8H was. Take a thin flat-head screwdriver or small chisel, insert it into the hole and place one edge into the inside of the torx, smash it with a hammer and crack off the security pin. Then a normal T8 driver can turn the screw. I'm glad the T8H from amazon worked for you, enjoy the mod.
