Introduction: Lightning Storm Box
Inspired by the various paper "Dream Boxes" or "Light Boxes" that display various images. I thought it be cool to add dynamic lightning by simulating a thunderstorm, using the arduino and neopixels.
Step 1: Materials
2pc 30cm pieces of wood brought from Michaels.
2pc 30cm pieces also from Michaels
Two long dowels to be cut to 4 28cm sections
One 2cm x 25cm long back board also from Michaels
One long dowel to be cut to 1cm thick, 11 1/2 deep sections.
Arduino Gemma https://www.adafruit.com/product/1222
Four Neopixels https://www.adafruit.com/product/1260
Red, Green and Black wires
Blue LED Strip Lights https://www.amazon.com/Excelvan-Waterproof-Flexibl...
Glue
Paper
Cottonballs
X-acto knife
foam
4 x screws
3/16 drill
optional 28cm piece of glass to fit into the frame if wanted
Step 2: The Wooden Box
Let's start with the basic box. The plans here will show the dimensions and depth. Feel free to add to or subtract from the plans.
If you can't read the plans, the box's dimensions are
30cm Length X 30cm Height
14 1/2 cm deep
1 cm should be dedicated to the electronics and light.
I suggest using natural wood so it brings out the lightning.
Four sections of 1 1/2 cm thick, 11 1/2 deep columns should be cut
a frame of 28 cm equal pieces of wood will be put at the front.
Step 3: Box Construction
Whether you made them from large pieces of wood, or bought them. Glue the 30 cm pieces together using glue, I recommend wood glue or hot glue. Let it sit for up to a day to give it time to set
Step 4: Inserting Frame
Cut four 28cm pieces from a large dowel and glue it about 1 1/2 inches from the opening. Let it set and cut four 11 1/2 inch dowel pieces with 1cm thickness. Glue those into the vertically in the corners. It should look as it does here.
Step 5: The Back
Get your 30 cm back piece and fit it onto the dowels. Drill four holes into the corners, that will be the screw holes.
Step 6: The Foam Pieces
Cut eight pieces of foam all 11 inches long and fit them behind the frame. This will hold the paper art. They should be a half a cm apart so they don't bunch up and you could have depth.
Step 7: The Paper Art
What you like to include if up to you. I myself wanted a hilly scene so it could be accented by light. Draw out your template on paper, using your x-acto knife. Cut along the lines until you get individual pieces. There are other instructables for this part for more details so I won't reiterate it.
Step 8: Mounting Your Paper Pieces.
Mount your paper pieces on top of the foam. Be sure there is a half CM seperation gap between them, so there could be depth in your art. I would use four pieces to start off. I put hills in the back, clouds in front, on top. Trees in the front then continued on until I had a house at front and center. You can add more if you like.
Step 9: The Clouds
First mount a large piece of paper behind the hills to cover up the opening. It should be two cms from the back panel. Paper diffuses the light giving the ambience and sense of awe you like. Now using glue, put the cotton balls at random intervers. Spacing them so it doesn't look bunched up and reveal white paper. This give the sense of distance.
Step 10: Now for the Magic. the Lights!!
We will use two lights. For the accent we will use 12v blue car LED strips to light it a night-time blue. Stick the strip to the bottom of the back piece. Now mount the batteries above. I suggest making foam containers so the batteries won't fall out.
I put a switch between the battery and the positive lead of the light. Now to mount the switch, drill a small hole in the side and extend the wire.
Step 11: And the Lightning!
For this one, we will use the Arduino Gemma and the Neopixels.
Upload the code from https://github.com/molecule/cloud-lightning/tree/v... by https://www.instructables.com/member/molecule13/
At the end of the void loop
delay(150) so the lightning would strike more often.
Now drill two small hole in the side for the arduino switch.
Step 12: Now Close It Up.
Close it up and drill four holes in the corners, where the screws will be mounted. Now screw it in.
Step 13: Now We Have a Scene
Step 14: Look It's a Storm!
I'm going inside! It's raining cats and dogs.
I am thinking of adding the sound of lightning and rain using a mp3 shield.
