Introduction: Lights Relay Rail
Home assistant simple project with 2 esp8266, 1 relay module and 1 stc013 on aller retour stairway ligths
The stc913 reading the voltage when ligths are on and an automation switch's momentary the relay module after a delay
Step 1:
After adding each esp8266 to the esphome builder via esphome web , edit the code adding simple attched codes
There is no need for accurancy for the stc013 ,only the amperage changes,so resistors and capacitors are not needed
Step 2:
Adding the automation ,home assistant reading amperage changes when lights are on and after 75 seconds delay fires up the relay.This is a aller-retour connection so i made an If statement to specify the code running only if at the end delay lights are still on , or someone closed manually
Step 3:
Final step to add the switch with the on-off state to the dashboard with 2 automations(can easily be at one automation combined but i prefer pure simplicity)
Thats all
