Introduction: LilCubey - a 3d Printable MATX Acrylic Cube Pc Case
About: 3d printed pc cases are cool.
This is a nice-looking, 3d printable pc case designed to stand out. The sharp corners and plexiglas give it a modern, futuristic and eye-catching appearance. Another great thing about the design is it only need a 180 x 180mm bed to be printed.
The airflow is also designed optimaly where the gpu and cpu manage to stay cool even on the most intense benchmarks.
Pc case features:
310mm GPU
205mm CPU Cooler / Single fan AIO
5 x 120mm Fans
SFX PSU
MicroATX/MiniITX
1 Slot for SATA SSD
Also alternatively to the writen guide with images below I recommend checking out this assembly video
For the tools you need:
  1. Soldering iron
  2. Screw driver
  3. Hot glue gun
  4. Drill
For the materials:
  1. 3-5 kg of filament (any color)
  2. Pack of m3 heated inserts
  3. Pack of m3 screws
  4. Pack of PC screws
  5. 3 plexi glas sheets (336 x 336 x 4)
  6. 16mm button
Step 1: Printing
3d printing the parts!
I personally used PETG and 15% infill, but higher infill will also work great.
These are all the parts you need to print:
(You can also check out the thingiverse)
Step 2: DownParts
Assembling the pc case!
You need 7 heat inserts for this step.
Just Insert the heat inserts like on the images.
Step 3: DownParts Assembly
First insert 1234Connector
Second slide in 3 and 2DownPart
Third, connect parts by inserting 4 LilConnectors
Step 4: MotherboardPieces
You need 7 heat inserts for the parts.
Insert the heat inserts exactly like on the images.
Step 5: MotherboardPieces Assembly
First slide through 6 and 5 MotherboardPiece
Second put MotherboardPieceAttacher into parts
Third, slide in 7 and 8MotherboardPiece
Fourth, insert 4 LilConnectors
Step 6: Sata SSD
If your planning to use a SATA SSD, i recomend sliding it in and screwing it in.
Step 7: BackParts
You need 11 heat inserts for this
Just some normal heat inserting like before
Step 8: BackParts Assembly
First slide in 9 and 10 BackPart
Second, slide in BackPartConnector
Third, insert the 16 mm button into the hole on 11BackPart
Fourth, slide in the 11 and 12 BackPart and insert 4 LilConnectors
Step 9: FrontPanels
You need 10 heat inserts for these parts
Nothing unusual, just heat inserting
Step 10: FrontPanels Assembly
You will need12 m3 8mm screws with12nuts
Before screwing in, screw in a nut fully into the screw. Then screw into pc case. Do that for all parts.
Step 11: MotherboardIoParts
You need9 m3 8mm screws with9 nuts
First take your SFX Power Supply, 18IoMotherboardPart and screw it in
Second, take the newly screwed in IoMotherboardPart and insert it into the pc case and screw it in
Third, take 19IoMotherboardPart and screw it in
Step 12: Front Fans
You'll need4 120mm fans +8 fan screws for this
Place in the 120mm fans and screw it in only where the image shows
Step 13: Motherboard Part
You need6 Standoffs + Motherboard screws and your motherboard (with cpu fan, ram and etc obviously installed in)
First Screw in the standoffs
Second insert and screw in the motherboard using as many motherboard screws you need
Third, Dont forget the Io Shield!
Step 14: MotherboardPiece
You need 4 heat inserts
Insert all heat inserts Into 21MotherboardPiece
Step 15: MotherboardIoParts Assembly
You need2 m3 8mm screws, 2 nuts, 1 120mm fan/AIOcpu cooler fan, screws for the fan/AIO and3 LilConnectors
First screw in 20MotherboardIoPart
Second put in3 LilConnectors into where shown
Third install your fan/AIO with whatever screws you need
Step 16: TopMbnBackConnectors
You'll need4 m3 8mm screws,2 LilConnectors and 2heat inserts
First screw in 20TopMbnBackConnector
Second screw in 21TopMbnBackConnector
Third insert2 LilConnectors
Fourth insert2Heat inserts as shown
Step 17: LongThings
You need 2 heat inserts and 2 LilConnectors
First take 24Longthing and insert in2 heat inserts
Second position 24 and 25Longthing and attach2 LilConnectors
Step 18: ExtraFrontConnectors
You need2 ExtraFrontConnectors and4fan screws
Place the ExtraFrontConnectors and screw it in with the fan screws
Step 19: 24 and 25LongThing
You need 4 m3 8mm screws
Grab 24 and 25LongThing, place it and screw it in
Step 20: GPU
You'll need2heat inserts, a GPU and2 m3 screws (any lenght that works)
First insert in2 heat inserts (or more depending on your setup)
Second, inserts in your beautiful GPU
Third, Screw in the GPU with the m3 screws
Step 21: 1 Heat Insert
You only need1 heat inserts for this
Just insert the 1 heat insert
Step 22: PlexiPlugA
You'll need 8 m3 8mmscrews and nuts
Place the Plexiplug'sA and then screw in
Step 23: PlexiPlugB
You'll need 8 heat inserts
First place the PlexiPlug'sB in
Second place the PlexiPlug'sB in
Third, add4 heat inserts
Fourth, add4 heat inserts
Step 24: Plexi Glas Drilling
For the pc case to be complete 3 336 x 336 mm plexi panels are needed. Each with 4 holes on the corners.
You need to drill4 holes per plexi glas as show on the images on every corner.
Step 25: PlexiPlugC
You need12 m3 6mm screws with nuts
First attach PlexiPlug'sC onto the pc case and screw it in. Do the exact same for all other panels.
Step 26: PlexiPlugD
I recomend using hot glue for this.
Attach the PlexiPlugs'D onto the PlexiPlug's and use some hot glue in beetween
Step 27: FINISH!
Now you've completed your cool-looking pc case, go ahead and enjoy it!
(Check out my channel for other cool 3d printable pc cases)
