Introduction: Lilliput USBlight
A mini USB Lamp......multi use......
Step 1: You Needed:
old mini lamp,a USB cable(male),hot glue,material for soldering,a power bank(new or diy for some type of uses)....
Step 2: How To.....
Take out from the lamp the mini frontal part with leds and soldering two wires(red and black) on it.....
add a led to the red wire (in serial mode) for push down the voltage:the lamp use 4.5 volt,USB
have 5 volt output......or simply resistor.......
use the hot glue for maintain two parts together and give form.......finish........
Step 3: You Can.....also.....
change the central led with a changing colors led,change others led with differents colors(blue,red,orange
green.....) for give a very good color of background if you use this lamp on the rear of your TV......
you can use a power bank for all usages you needed like camping,fishing,work......
Thank's to watch.......... !!
