Introduction: LilyGo T-Display RP2040 - Tutorial - Installing the Firmware and First Steps With the Board Display
This tutorial is intended for the LilyGo T-Display RP2040 board, which has a raspberry pi microcontroller. Follow the step by step to correctly install the card's firmware.
All files are available in compressed form, just download and unzip, following the instructions later.
Esse tutorial é destinado para a placa LilyGo T-Display RP2040, que possui um microcontrolador da raspberry pi. Siga o passo a passo para instalar corretamente o firmware da placa.
Todos os arquivos estão disponiveis de forma compactada, é só baixar e descompactar, seguindo as instruções posteriormente.
Step 1: TUTORIAL
Instal board arduino ide:
- Open up the Arduino IDE and go to File->Preferences.
- In the dialog that pops up, enter the following URL in the "Additional Boards Manager URLs" field:
https://github.com/earlephilhower/arduino-pico/releases/download/global/package_rp2040_index.json
- Go to Tools->Boards->Board Manager in the IDE
- Type "pico" in the search box and select "Add":
Still in the IDE, go to Tools - Boards - Raspberry Pi RP2040 (2.6.5) - Raspberry Pi Pico
Select the board's COM port (Connect the board to the USB first using the data cable)
1°Download the github folder at this link:
https://github.com/Xinyuan-LilyGO/LILYGO-T-display-RP2040
or
https://1drv.ms/u/s!AnXRVFnU40YHhno_br756iL753vp?e=B11usY
2°Unzip the zip file.
3°Open the firmware folder
Do this now:
Do all this with the board connected to the computer and the Arduino IDE open!!!
Open image 1 to see the buttons better.
1° Hold the boot button and do not let go
2°Hold the reset button at the same time for 1 or 2 seconds and then release
3°Release the boot button 1 second after releasing the reset button
Do all this with the board connected to the computer and the Arduino IDE open.
It will then open a USB device (it's the one on the board) automatically in your file manager.
Do it now:
1°In the firmware folder that you opened, there is a file in the 'UF2' format, IT IS NOT THE INO!, drag the file 'firmware.UF2' to the USB device that opened automatically called: 'RPI-RP2'
(Maybe it's another name, here it was).
2°Close the USB device folder, you will see that an animation will start on the screen!!
3° Now add the library to the file, add it manually, you should know how to do it, I'll leave the folder next to the example code folder that I saved.
4° Test the example code by sending it through the Arduino IDE, selecting the right board in the IDE and the port.
5°Use this link to add the board: https://github.com/earlephilhower/arduino-pico/releases/download/global/package_rp2040_index.json
Install the package described in image 1.
It doesn't work with another!
Em português
Instalação da placa no arduino ide:
Abra o Arduino IDE e vá para Arquivo->Preferências.
Na caixa de diálogo que aparece, digite o seguinte URL no campo 'Additional Boards Manager URLs':
E clique em Ok.
Vá para Ferramentas->Placas->Gerenciador de Placas no IDE
Digite 'pico' na caixa de pesquisa e selecione 'Adicionar':
Ainda na IDE, vá em ferramentas - placas - Raspberry Pi RP2040 (2.6.5) - Raspberry Pi Pico
Selecione a porta COM da placa (Conecte antes a placa na USB usando o cabo de dados)
1°Baixe a pasta do github nesse link:
ou
2°Descompacte o arquivo zip.
3°Abra a pasta firmware
Faça esse procedimento agora:
Faça tudo isso com a placa conectada no computador e a IDE do arduino aberta!!!
Abra a imagem 1 para ver melhor os botões.
1° Segure o botão de boot e não solte
2°Segure o botão de reset ao mesmo tempo por 1 ou 2 segundos e depois solte
3°Solte o botão de boot 1 segundo depois de soltar o de reset
Faça tudo isso com a placa conectada no computador e a IDE do arduino aberta.
Em seguida, vai abrir um dispositivo USB (é o da placa) automaticamente no seu gerenciador de arquivos.
Faça isso agora:
1°Na pasta firmaware que você abriu, tem um arquivo no formato "UF2", NÃO É O INO!, arraste o arquivo "firmaware.UF2" para o dispositivo USB que abriu automaticamente chamado: "RPI-RP2"
(Talves seja outro nome, aqui foi esse).
2°Feche a pasta do dispositivo USB, você verá que vai começar uma animação na tela!!
3° Agora adicione a biblioteca no arquino, adicione manualmente, você deve saber como já faz isso, deixarei a pasta junto a pasta do código de exemplo que salvei.
4° Teste o código de exemplo enviando através da ide do arduino, selecionando a placa certa na ide e a porta.
5°Use esse link para adicionar a placa:https://github.com/earlephilhower/arduino-pico/releases/download/global/package_rp2040_index.json
Instale esse pacote: O nome ta na imagem 1.
Não funciona com outro!
