Introduction: LilyPad Arduino Binary Clock
I like the binary clock project in the book, "30 Arduino Projects for the Evil Genius" by Simon Monk. The only problem was that his clock had problem keeping time. '
I tweaked the code a little and added the RTC module and I think this is an improvement.
The reed switch is so you can set the time. When activated with a magnet the minutes and hours move faster so you can run it through the cycle until it reaches the time you want to set it at. When you remove the magnet from the switch, it slows down to normal and keeps time from there.
1 x LilyPad Arduino 328
1 x DS3231 RTC module
1 x Reed switch
4 x red LEDs,
6 x green LEDs
6 x yellow LEDs
14 × 220Ω resistor
1 × 10K resistor
You need the "Time" file from the arduino library.3
Step 1: The Circuit
This is the circuit on a breadboard.
Step 2: The Code
Here's my code:
#include <Wire.h>
#include <RTClib.h>
RTC_DS3231 rtc;
// 4-bit hours (12h format)
int hourLEDs[] = {A1, A2, A3, A0};
// 6-bit minutes
int minuteLEDs[] = {5, 4, 3, 2, 1, 13};
// 6-bit seconds
int secondLEDs[] = {11, 10, 9, 8, 7, 6};
// All LEDs in order for spin animation
int loopLEDs[] = {5, 4, 3, 2, 1, 13, 11, 10, 9, 8, 7, 6, A1, A2, A3, A0};
// Reed switch connected to 5V, using INPUT_PULLUP
const int switchPin = 12;
unsigned long lastUpdate = 0;
const unsigned long normalDelay = 1000;
const unsigned long fastDelay = 100;
int lastSyncHour = -1;
void setup() {
Wire.begin();
rtc.begin();
// Kör bara EN gång för att ställa tiden:
// rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
for (int i = 0; i < 4; i++) {
pinMode(hourLEDs[i], OUTPUT);
for (int i = 0; i < 6; i++) {
pinMode(minuteLEDs[i], OUTPUT);
pinMode(secondLEDs[i], OUTPUT);
pinMode(switchPin, INPUT_PULLUP);
// ⏱️ Direkt uppdatera display med tid från RTC vid uppstart
DateTime now = rtc.now();
updateDisplay(now.twelveHour() == 0 ? 12 : now.twelveHour(), now.minute(), now.second());
void loop() {
bool fastForward = digitalRead(switchPin) == HIGH;
int delayTime = fastForward ? fastDelay : normalDelay;
// Fast-forwardläge
if (fastForward && millis() - lastUpdate >= delayTime) {
int newMinute = now.minute() + 1;
int newHour = now.hour();
int newDay = now.day();
int newMonth = now.month();
int newYear = now.year();
if (newMinute >= 60) {
newMinute = 0;
newHour++;
if (newHour >= 24) {
newHour = 0;
newDay++;
rtc.adjust(DateTime(newYear, newMonth, newDay, newHour, newMinute, now.second()));
lastUpdate = millis();
// 🔄 Synka om från RTC varje hel timme
if (now.minute() == 0 && now.second() == 0 && now.hour() != lastSyncHour) {
now = rtc.now();
lastSyncHour = now.hour();
// ⏳ Spin-animation vid varje full timme
if (now.minute() == 0 && now.second() == 0) {
int hour = now.twelveHour();
if (hour == 0) hour = 12;
spin(hour);
// 💡 Uppdatera LED-visning
delay(delayTime);
void updateDisplay(int hour, int minute, int second) {
setOutput(hourLEDs, 4, hour);
setOutput(minuteLEDs, 6, minute);
setOutput(secondLEDs, 6, second);
void setOutput(int *ledArray, int numLEDs, int value) {
for (int i = 0; i < numLEDs; i++) {
digitalWrite(ledArray[i], bitRead(value, i));
void spin(int count) {
for (int i = 0; i < count; i++) {
for (int j = 0; j < 16; j++) {
digitalWrite(loopLEDs[j], HIGH);
delay(50);
digitalWrite(loopLEDs[j], LOW);
Step 3: Final Clock
Here’s a movie of the final result.
