Introduction: Line Follower Basic Using Arduino Nano
Line Follower Basic using Arduino Nano is a line follower robot with arduino nano controller which using 6 line sensors. This robot is also equipped with PID controller (Proportional Integral Derivative). It makes the robot can navigate well.
Step 1: Materials You Need
You will need:
- Arduino Nano CH340
- Line Follower Basic Board
- Line sensor of Line Follower
Step 2: Schematic
Step 3: Setup
Solder the line sensors that have been prepared with and then pair it with IDC socket that is on board of line follower basic arduino nano.
Step 4: Code
#include <EEPROM.h>
#include <LiquidCrystal_SR.h>
#include <Wire.h>
LiquidCrystal_SR lcd(3,10,2);
#define eepromKp 0
#define eepromSpeed 1
#define eepromKd 2
#define button1 13
#define button2 12
#define button3 1
#define button4 0
#define echo 10
#define trigger 11
#define pwmOne 5
#define inAOne 4
#define inBOne 9
#define pwmTwo 6
#define inATwo 8
#define inBTwo 7
int sensorVal[6];
void setup() {
// put your setup code here, to run once:
pinMode(button1, INPUT_PULLUP);
pinMode(button2, INPUT_PULLUP);
pinMode(button3, INPUT_PULLUP);
pinMode(button4, INPUT_PULLUP);
pinMode(pwmOne, OUTPUT);
pinMode(inAOne, OUTPUT);
pinMode(inBOne, OUTPUT);
pinMode(pwmTwo, OUTPUT);
pinMode(inATwo, OUTPUT);
pinMode(inBTwo, OUTPUT);
Serial.begin(9600);
delay(1000);
pinMode(A0, INPUT);
pinMode(A1, INPUT);
pinMode(A2, INPUT);
pinMode(A3, INPUT);
pinMode(A4, INPUT);
pinMode(A5, INPUT);
lcd.begin(16,2);
lcd.setCursor(0,0);
lcd.print(“`sfe-electronics”);
lcd.setCursor(0,1);
lcd.print(“`LF Basic 6 Sens”);
delay(2000);
lcd.clear();
unsigned char Kp = 25;
unsigned char Kd = 9;
unsigned char Ts = 1;
unsigned char max_pwm_ref=125;
int error, last_error, MV,pid_l,pid_r,D,D1,D2,D3,P,Pd, bitSensor;
int Max_MV;
char lcdBuff[16];
void loop() {
Kp = EEPROM.read(eepromKp);
//max_pwm_ref = EEPROM.read(eepromSpeed);
Kd = EEPROM.read(eepromKd);
lcd.setCursor(0,0);
lcd.print(“Kp Speed Kd”);
lcd.setCursor(0,1);
sprintf(lcdBuff,“%3d %3d %3d”,Kp, max_pwm_ref,Kd);
lcd.print(lcdBuff);
if(digitalRead(button3) == LOW)
delay(150);
Kp++;
EEPROM.write(eepromKp, Kp);
if(digitalRead(button2) == LOW)
delay(150);
Kd++;
EEPROM.write(eepromKd, Kd);
if(digitalRead(button4) == LOW)
while(1)
robotRun();
void readSens()
sensorVal[0] = digitalRead(A0); sensorVal[1] = digitalRead(A1); sensorVal[2] = digitalRead(A2);
sensorVal[3] = digitalRead(A3); sensorVal[4] = digitalRead(A5); sensorVal[5] = digitalRead(A4);
void robotRun()
readSens();
bitSensor = ((sensorVal[0]*1)+(sensorVal[1]*2)+(sensorVal[2]*4)+(sensorVal[3]*8)+(sensorVal[4]*16)+(sensorVal[5]*32));
switch(bitSensor)
case 0b011111: error = –5; break;
case 0b001111: error = –4; break;
case 0b101111: error = –3; break;
case 0b100111: error = –2; break;
case 0b110111: error = –1; break;
case 0b110011: error = 0; break;
case 0b111011: error = 1; break;
case 0b111001: error = 2; break;
case 0b111101: error = 3; break;
case 0b111100: error = 4; break;
case 0b111110: error = 5; break;
case 0b111111: if(error > 3) {error=6;}
if(error <– 3){error=–6;} break;
Max_MV = Kp*5; //limiting the output value of the PID results
//### rumus PID digital
P = Kp * error;
D1 = Kd*8;
D2 = D1 / Ts;
D3 = error – last_error;
D = D2 * D3;
last_error = error;
MV = P + D;
if(MV>=–Max_MV && MV<=Max_MV) //if the PID output does not exceed the PID output limit value then the robot will run
{ //forward with the right and left PWM settings
pid_l = max_pwm_ref – MV;
pid_r = max_pwm_ref + MV;
if (pid_l < 0) pid_l = 0;
if (pid_l > 255) pid_l = 255;
if (pid_r < 0) pid_r = 0;
if (pid_r > 255) pid_r = 255;
forward(pid_r,pid_l);
else if(MV<–Max_MV) //if the PID output is smaller than the PID output limit value the robot will rotate RIGHT
turnLeft(200,100);
else if(MV>Max_MV) //if the PID output is larger than the PID output limit value the robot will rotate LEFT
turnRight(100,200);
else
lcd.setCursor(0,0);
sprintf(lcdBuff,“%i%i%i%i%i%i”, sensorVal[0],sensorVal[1],sensorVal[2],sensorVal[3],sensorVal[4],sensorVal[5]);
lcd.print(lcdBuff);
lcd.setCursor(0,1);
sprintf(lcdBuff, “%2d %3d %3d”, error, pid_l, pid_r);
lcd.print(lcdBuff);
void forward(int valLeft, int valRight)
digitalWrite(inAOne, LOW);
digitalWrite(inBOne, HIGH);
analogWrite(pwmOne, valLeft);
digitalWrite(inATwo, HIGH);
digitalWrite(inBTwo, LOW);
analogWrite(pwmTwo, valRight);
void backward(int valLeft, int valRight)
digitalWrite(inAOne, HIGH);
digitalWrite(inBOne, LOW);
digitalWrite(inATwo, LOW);
digitalWrite(inBTwo, HIGH);
void turnRight(int valLeft, int valRight)
void turnLeft(int valLeft, int valRight)
void stopRun()
analogWrite(pwmOne, 0);
analogWrite(pwmTwo, 0);
