Introduction: Linear Actuator in 5 Minutes
Always wanted the linear motion but were stuck with the circular motion of the motor .You have landed on the correct place
Step 1: Supplies Needed
List of the material you need is
- a power drill
- a flat file
- tape
- a bolt (of about 75 mm length)
- 3 nuts of that size
- motor
- wire cutter
- a coupler used in tube lights
Step 2: Making the Shaft
Take the bolt fix it in the drill machine and stick the file flat with help of a tape
Step 3: Coupler
take the coupler remove its plastic shaeth and arrange them
Step 4: Piece for Movement
take the 3 nuts and screw them on the bolt such that the bolt is free to move . Now solder the 3 nuts together
Step 5: Completed
On one polarity goes up and on other goes down
