Introduction: LinkIt One Tutorials - #6 GPS Device
In my previous tutorial I showed how to install an external library, connect to a Grove Connector header and use a Grove LCD RGB Backlight display.
In this tutorial I will be connecting the LCD display, GPS antenna and battery to the LinkIt One board and making a GPS device that will give your exact position in the world.
Step 1: Materials Required
LinkIt One board
Micro USB cable
Li-Ion rechargeable battery
This will be in the box that contained the LinkIt One. It has one red and one black wire going to a white connector.
GPS antenna
This will be in the box that contained the LinkIt One. It is a 2.5 cm square antenna.
Arduino IDE
Grove LCD RGB Backlight Arduino libraries
Refer to tutorial 5 if you have not installed the libraries
Step 2: Install the GPS Antenna, Grove LCD and Battery
If the LinkIt One board is connected to the computer via USB, disconnect it now.
Gently connect the GPS antenna to the LinkIt One board on the connector marked "GPS ANT". This connector is at the top of the board if the antenna connectors are to the left of the board.
if you are unsure how to connect the antenna, follow tutorial #4, remembering to plug the antenna into "GSM ANT" rather than "WIFI/BT ANT".
Connect the Grove LCD RGB Backlight board to the Grove header with "SCL SDA 5V GND"as described in tutorial #5.
There is a large switch on the LinkIt One board marked PWR_SW with one side that reads "BAT" and the other side that reads "USB" (conveniently this is the side next to the micro USB port). Ensure that this is switched to "USB".
Take the battery connector (2 wires - red and black) and ensure that the black wire of the connector is near the edge of the board and the red one is towards the centre of the board.
Gently push it into the cream coloured socket at the edge of the board. It is snap fit so you will feel it click into place.
Ensure the battery is connected properly by gently trying to remove the connector. It should give a lot of resistance. If it comes out push it in again a little more firmly.
Connect the micro USB cable.
Step 3: Write the GPS Program and Output to LCD
Start the Arduino IDE.
Open the document above called LCD_GPS.ino.txt and copy/paste the contents into your Arduino IDE, overwriting the previous contents.
Upload the code to your LinkIt One board.
When it is uploaded the LCD will display "GPS on, waiting" and will begin scanning for GPS (Global Positioning Satellites).
The display will change and display 2 lines of information
Line 1 displays "LAT", your latitude, N or S depending on above or below the equator and "ST"
Line 2 displays "LON", your longitude, E or W depending on your position relative to Greenwich, UK and a number. This number is how many GPS satellites are being used to geolocate your position. More is better.
A nice feature is that the backlight changes colour depending on the number of satellites visible at that time.
Switch the BAT/USB switch to BAT and disconnect the USB cable.
Take the board and attachments outside to an area with an unobstructed view of the sky (don't stand under a tree!).
After a short period of time the LCD should change colour as it locks on to satellites and your position should change as accuracy increases.
Do you want to know where you are? Google Maps can show your position if you
Step 4: Where Next
Every tutorial you follow will expand the capabilities of the LinkIt One.
I bet you can think of something you could do with the knowledge you already have.
Part of learning is experimenting so go ahead. See what you can come up with and let me know your ideas in the comments section.
