Linkit One GPS (sending SMS of GPS Location to Mobile)
Intro: Linkit One GPS (sending SMS of GPS Location to Mobile)
This instructable solves the problem of printing GPS location on serial monitor .
We'll send that location in the form of SMS to our mobile than we will take the important part and than paste it on Google maps.
STEP 1: Parts
Parts:
• Linkit One
• Linkit One USB cable
• GSM Antenna
• GPS Antenna
• Battery (Linkit one)
• Sim card
• Linkit One
• GSM Antenna
• GPS Antenna
• Sim card
STEP 2: Code
#include
gpsSentenceInfoStruct info;
char buff[256];
static unsigned char getComma(unsigned char num,const char *str)
unsigned char i,j = 0;
int len=strlen(str);
for(i = 0;i < len;i ++)
if(str[i] == ',')
j++;
if(j == num)
return i + 1;
return 0;
static double getDoubleNumber(const char *s)
char buf[10];
unsigned char i;
double rev;
i=getComma(1, s);
i = i - 1;
strncpy(buf, s, i);
buf[i] = 0;
rev=atof(buf);
return rev;
static double getIntNumber(const char *s)
char buf[10];
unsigned char i;
double rev;
i=getComma(1, s);
i = i - 1;
strncpy(buf, s, i);
buf[i] = 0;
rev=atoi(buf);
return rev;
void parseGPGGA(const char* GPGGAstr)
/* Refer to http://www.gpsinformation.org/dale/nmea.htm#GGA
* Sample data: $GPGGA,123519,4807.038,N,01131.000,E,1,08,0.9,545.4,M,46.9,M,,*47
* Where:
* GGA Global Positioning System Fix Data
* 123519 Fix taken at 12:35:19 UTC
* 4807.038,N Latitude 48 deg 07.038' N
* 01131.000,E Longitude 11 deg 31.000' E
* 1 Fix quality: 0 = invalid
* 1 = GPS fix (SPS)
* 2 = DGPS fix
* 3 = PPS fix
* 4 = Real Time Kinematic
* 5 = Float RTK
* 6 = estimated (dead reckoning) (2.3 feature)
* 7 = Manual input mode
* 8 = Simulation mode
* 08 Number of satellites being tracked
* 0.9 Horizontal dilution of position
* 545.4,M Altitude, Meters, above mean sea level
* 46.9,M Height of geoid (mean sea level) above WGS84
* ellipsoid
* (empty field) time in seconds since last DGPS update
* (empty field) DGPS station ID number
* *47 the checksum data, always begins with *
double latitude;
double longitude;
int tmp, hour, minute, second, num ;
if(GPGGAstr[0] == '$')
tmp = getComma(1, GPGGAstr);
hour = (GPGGAstr[tmp + 0] - '0') * 10 + (GPGGAstr[tmp + 1] - '0');
minute = (GPGGAstr[tmp + 2] - '0') * 10 + (GPGGAstr[tmp + 3] - '0');
second = (GPGGAstr[tmp + 4] - '0') * 10 + (GPGGAstr[tmp + 5] - '0');
sprintf(buff, "UTC timer %2d-%2d-%2d", hour, minute, second);
Serial.println(buff);
tmp = getComma(2, GPGGAstr);
latitude = getDoubleNumber(&GPGGAstr[tmp]);
tmp = getComma(4, GPGGAstr);
longitude = getDoubleNumber(&GPGGAstr[tmp]);
sprintf(buff, "latitude = %10.4f, longitude = %10.4f", latitude, longitude);
tmp = getComma(7, GPGGAstr);
num = getIntNumber(&GPGGAstr[tmp]);
sprintf(buff, "satellites number = %d", num);
else
Serial.println("Not get data");
void setup() {
// put your setup code here, to run once:
Serial.begin(115200);
LGPS.powerOn();
Serial.println("LGPS Power on, and waiting ...");
delay(3000);
while(!LSMS.ready){
delay(1000);
void loop() {
// put your main code here, to run repeatedly:
Serial.println("LGPS loop");
LGPS.getData(&info);
LSMS.beginSMS(" Enter No.");
LSMS.print((char*)info.GPGGA);
parseGPGGA((const char*)info.GPGGA);
delay(2000);
LSMS.endSMS();
char buff[256];
if(str[i] == ',')
j++;
if(j == num)
return i + 1;
return 0;
char buf[10];
unsigned char i;
double rev;
i=getComma(1, s);
i = i - 1;
strncpy(buf, s, i);
buf[i] = 0;
rev=atof(buf);
return rev;
char buf[10];
unsigned char i;
double rev;
i=getComma(1, s);
i = i - 1;
strncpy(buf, s, i);
buf[i] = 0;
rev=atoi(buf);
return rev;
* Where:
* 1 = GPS fix (SPS)
* 2 = DGPS fix
* 3 = PPS fix
* 5 = Float RTK
* ellipsoid
double latitude;
double longitude;
else
void setup() {
LGPS.powerOn();
delay(3000);
while(!LSMS.ready){
delay(1000);
void loop() {
delay(2000);
LSMS.endSMS();
STEP 3: Finding It on Google Maps
8960.0000,N,00000.0000,E,
Copy this and paste it on Google maps replace , with ° and search you' ll get your location.
Good Luck.
Good Luck.
