Introduction: Linkit One: Traffic Light Simulation
In this tutorial I will share to you on how you can simulate a traffic light system using Linkit One board. This could be a good starting project for people who just learning microcontroller.
Step 1: Hardware
Fof this project we will use a very minimum components, such as:
- Linkit One Board
- 3 LED (Red, Yellow, Green)
- 3 330 Ohm Resistor
- 4 Jumper Wires
- A bread board
- Micro USB Cable
Step 2: Setup Linkit One
Step 3: Hardware Setup
Make the connection from Linkit One board to your LED Just Like in the picture. In this tutorial we wiil use 3 digital pin such as:
Pin 8 ----->Green LED
Pin 9 -----> Yellow LED
Pin 10 ----->Red LED
Step 4: The Code and Result
After you make all the connection. Upload the following code to Linkit One board and the Upload it. The you will see each light turn on every 3 second. you can change the duration simply by changing the delay
int redPin = 10;
int yellowPin = 9; int greenPin = 8; void setup() { pinMode(redPin, OUTPUT); pinMode(yellowPin, OUTPUT); pinMode(greenPin, OUTPUT); } void loop() { digitalWrite(redPin, HIGH); digitalWrite(yellowPin, LOW); digitalWrite(greenPin, LOW); delay(3000); digitalWrite(redPin, LOW); digitalWrite(yellowPin, HIGH); digitalWrite(greenPin, LOW); delay(3000); digitalWrite(redPin, LOW); digitalWrite(yellowPin, LOW); digitalWrite(greenPin, HIGH); delay(3000);}
