Introduction: Lip Balm Key Chain
My wife doesn't like getting chapped lips.
Who does, really?
The only problem is that she tends to lose her favorite brand of balm. We must have spent $100 so far, and she has yet to finish a single tube.
In an effort to help, I attached it to her keys. Now she has it when she needs it.
Who does, really?
Step 1: What You Will Need:
Needle
Heavy duty thread
Needle-nose pliers
Lip balm with a screw- on cap
Heavy duty thread
Needle-nose pliers
Step 2: Poke Some Holes in the Cap.
Take the needle and poke two holes on either side of the dimple on top of the cap.
You may need to use the needle-nose pliers to push the needle through the cap. It doesn't take a great deal of effort.
While the needle is in sticking in the plastic, make nice wide circles to open up the holes. The holes should be big enough that the needle should easily pass through the hole, eye and all.
Step 3: Do Some Sewing.
Thread the needle with some heavy duty thread. If you look inside the cap you will see that there is a little spike that plugs the hole on the applicator on the tube of balm. Pass the thread through the cap from one hole to the other, so that the first pass goes on one side of this spike and the next pass goes on the other side. I made 4 passes.
Tie off the thread.
I used a woven thread, so I melted the end with a lighter to keep from fraying.
Tie off the thread.
Step 4: Attach the Key Ring.
Pass the key under the thread. I found that it helps to use the dimple in the top of the cap the get the ring started, otherwise it's a pretty tight fit.
Avoid faying the thread.
Note: Pliers are not necessary for this step, They're just holding every thing up so I could take the picture.
Step 5: Attach to Keys.
Attach the cap/keyring to your other keys.
Screw the cap onto the balm and you're all done!
I found a spring-loaded hasp because my wife requested that she be able to easily take the whole assembly off her key ring. It is not necessary.
I have only done this with one brand of balm. I suspect that it will work on others, depending on the material the cap is made of. If the cap is made of a harder plastic, you can heat the needle to make the holes.
Hope you found this instructable useful.
Thanks and Enjoy!
Thanks and Enjoy!
