Introduction: Liquid Smoke or Fake Bomb
This simple liquid smoke maker could also be used as a fake bomb. Liquid smoke could be poured from one container to another. You can also use it as a fake bomb.ENJOY
Step 1: You Will Need...
1 Lighter 2 Straws 2-5 Pieces of tissue paper (the more the better) Duct tape Scissors Thin glass bottle
Step 2: The Straws
First you will need to tape the two straws together. It should look like this.
Step 3: The Smoking Part
Next you should roll up all the tissues then tape them to the straws. It should look like this.blow through the straws to make sure the smoke could pass through.
Step 4: Putting Everything Together
Next put the object you made in step 3 in the thin glass bottle.
Step 5: Liquid Smoke or Fake Bomb
If you want to make liquid smoke ONLY put the thin glass bottle alone in the freezer from 5 to 10 minutes then put it together then light the top when smoke is starting to settle in the bottom pour it to the ground or to another container. If you want to make the fake bomb just light the tissue paper in the top and pretend it is a bomb. Now you are done.
