Litter Box House for Under $10
Intro: Litter Box House for Under $10
Does your cat need a little privacy? Want to hide your litter box from guests? Are you on a budget and find regular litter box houses crazy expensive? Then this is the instructable for you!
STEP 1: Supplies
Supplies:
1 cheap side table, I used the Lack side table from Ikea - $7.99
4 sheets of poster board, I got 2/$1.00 at Dollar Tree - $2.00
Adhesive of some sort, I used mounting tape but I'm sure you could use regular tape or hot glue or whatever
Tools:
Scissors
Measuring Tape
Pencil
Straight Edge
Tools:
Scissors
Measuring Tape
Pencil
Straight Edge
STEP 2: Measure, Measure, Cut
Start by measuring each side of the table. Turns out the lack table is square and saved me some trouble. 21.5" across the top, 18" down and for some reason 21.25" across the bottom.
I decided to take off a half inch on the bottom because the table will be sitting on carpet.
Using a pencil on the wrong or inside part of the poster board I mark a square 21.5"(W) x 17.5"(H). To compensate for the 1/4" difference between the top and bottom I make a mark at 2" down on the height and a 1/4" in. This should give you a T shape.
After cutting out the first piece and checking it against the table I use it as a template on the other 3 pieces of poster board.
STEP 3: Attach the Poster Board
I used little pieces of mounting tape on the top corners and in the middle. Carefully line up the top of the board with the top of the table. It helps to be at eye level for that.
After attaching the top, add a piece of tape to the bottom corners and smooth it down the sides to make sure it is flat. Repeat with 2 more sides.
STEP 4: Add the Cat Door
Now is the time to cut out the cat door. I pretty much eyeballed this one. I marker where the middle was and made an arch. If you're unsure about how much to cut you can always go smaller than you think and then cut out more.
After you've cut out the door just attach it like the rest, except maybe add more tape because this is where it might fall apart from your kitty rubbing against it while entering and exiting.
STEP 5: All Done!
The finished product. Took me maybe 45 minutes to do this.
I thought about using foam core, but I know my cat will tear into that in no time. If I were looking for a more permanent solution I might use some bead board and me it look really nice.
These tables come in lots of colors, or maybe you or your kids could decorate the poster board for fun.
Please note that I had to measure the space under the table (18") and find a litter box that would fit between the legs. I found one at a big pet store, but it's really only big enough for one cat. If you have multiple cats this might not work for you. Or if you have a larger litter box already you might need to buy a smaller one.
Vampyra65 10 years ago
