Little Bunny Foo Foo in His Bed
Intro: Little Bunny Foo Foo in His Bed
Little Bunny Foo Foo got tire of boppin' the field mice on their heads so he decided to take a nap in his bed. Here is what you will need to make this cute Little Bunny and his Bed.
MATERIALS:
Crochet Hook Size G-6
Safety Eyes Size 7.5mm
Safety Nose Brown 12mm
I love this Yarn Toasted Almond (A)
Vanna’s Choice Baby Sweet Pea Green (B)
Vanna’s Choice Baby Lamb (C)
Cluster Fluff-fiber fill
1 Blunt Needle
Stitch Markers
SIZE: Around 5 inches tall
NOTES:
Work in continuous rounds; do not join or turn. Place a stitch marker to indicate beginning of round; move marker up as work progresses. I use the Magic Circle/Adjustable ring method because you can pull the center of your work tightly closed. There are a lot of great videos on how to make a Magic Circle on YouTube, if you still are unable to make this just make the: Ch 2. Rnd 1: Work 6 sc in first chain. Place marker in first stitch for beginning of round; move marker up as each rnd is completed in place of the Magic Circle.
ABBREVIATIONS / REFERENCES:
St(s) = stitch (es) Sc = single crochet Ch = chain Sc2tog = single crochet 2 together Rnd = round
Beg = begin, beginning, Rep = repeat, Sl St = slip stitch
MATERIALS:
1 Blunt Needle
Stitch Markers
NOTES:
STEP 1: Bunny Foo Foo
BUNNY: With A
Rnd 1: Begin work by making a Magic Circle with 6 sc. Place marker in first stitch for beginning of round; move marker up as each rnd is completed.
Rnd 2: 2 sc into each st around (12)
Rnd 3: *2 sc in next st, sc in next st, rep from * around - 18 sc.
Rnd 4 - 7: Sc in each st around.
Rnd 8: sc in each of next 6 sts, Sc2tog three times, sc in the remaining 6 sts.
Rnd 9: sc in each of next 6 sts, in the next three scs 2 sc in each st, sc in the remaining 6 sts.
Rnd 10: sc in each of next 8 sts, 2 sc in each of the next 2 sts, sc in remaining 8 sts Stuff with Fluff.
Rnd 11 - 15: Sc around. Attach the eyes in Rnd 6 and the nose in Rnd 7 where the Bunny Curves in; according to package directions, make sure you use pictures as a guide.
Rnd 16: *sc in each of next 3 sts, Sc2tog, rep from * around.
Rnd 17: *sc in each of next 2 sts, Sc2tog, rep from * around.
Rnd 18: *sc in each of next 1 sts, Sc2tog, rep from * around.
Rnd 19: *Sc2tog two times, stuff with fluff fasten off and sew closed weave in ends.
STEP 2: Ears, Legs and Tail
EARS : With A
Rnd 2 - 4: Sc in each st around. Fasten off leave a tail sew the open end of the ear closed. Once sewed closed sew to the top of the head.
TOP LEGS: make 2 with A
Rnd 2-3: Sc in each st around. Fasten off and leave a tail to sew legs to body.
BOTTOM LEGS make 2 with A
Rnd 1: Begin work by making a Magic Circle with 7 sc. Place marker in first stitch for beginning of round; move marker up as each rnd is completed.
Rnd 2-5: Sc in each st around.
Rnd 6: *Sc2tog two times, then sc in the remaining scs. Fasten off leaving a long tail to sew to body.
TAIL:
TAIL: With (C) make a pompom by using a credit/gift card. Begin by wrapping the yarn around the shortest width of the card. Continue to wrap around for 50 times. Cut yarn then cut a piece of (C) yarn 8 inches long and use the blunt needle to insert in between the yarn and the card only pull halfway through. Pull tight towards the top of the card. Tie in a knot, slide the yarn off (once you slide it off it will be loose) then wrap the two strands around once more pulling tight and tie a second knot tighter than the first knot. Cut the loops fluff out, do not trim the strands you used to tie the tail but trim the rest of the tail down to size. Use the two strands to sew the tail to the back of the Bunny.
TAIL:
STEP 3: Bed
BED: With (B)
Rnd 1: Make a magic circle with 6 ch spaces Place marker in first stitch for beginning of round; move marker up as each rnd is completed.
Rnd 2: Work 2 sc in each sc around - 12 sts
Rnd 3: * sc in next st, 2 sc in next st, rep from * around - 18 sts
Rnd 4: * sc in each of next 2 sts, 2 sc in next st, rep from * around - 24 sts
Rnd 5: * sc in each of next 3 sts, 2 sc in next st, rep from * around - 30 sts
Rnd 6: * sc in each of next 4 sts, 2 sc in next st, rep from * around - 36 sts
Rnd 7-12: sc around – 42 sts Fasten off weave in ends. For the Strands around the bed cut color B into 5 inch strips insert crochet hook into the edge of the bed pull 2 stands through a little making a loop then pull the ends of those strands through that loop pulling tight to form the tassel ends of the Bed.
3 Comments
Yarnabees 12 years ago
"Little Bunny Foo Foo
Hopping through the forest
Scoopin' up the field mice
Bop 'em on the head!
Then the Good Fairy came and said:
'Little Bunny Foo Foo
I don't wanna see you
I'll give you 3 chances,
And if you don't behave, I will turn you into a goon!"
CatTrampoline 12 years ago
Penolopy Bulnick 12 years ago
I can't remember all of the words! But I have the tune in my head :)
