Introduction: Geek Turtle -
A Childhood Pranks gifted from my Dad !
Step 1: Bill of Materials & Tools
- Materials :
- 1 Wine Cork
- Thread Spool
- Elastic Money Band
- Barbecue Stick ( or cutted sprue bar - from models )
- Paper Clip
- Metal Washer ( 0,78 inch ).
Tools :
- Cutter ( be carefull just Adults can operate it !! )
- Nose Pliers
- Cutter Pliers
For Prettiers :
- Gouache Ink ( Any Color )
- Micro Brush .
Step 2: Cut Some Littles Teeth at Thread Spool ( Wood or Plastic One)
Safe First : Only Adults to do this Step !
Step 3: Cut the Wine Cork : Two Slices ( 0,6 Mm - or So 0
Be Carefull with This Step ( Adults only can Do It ) !
Step 4: Cut a Little ( Gap ) to Set Up the Axle ( Wood or Plastic Sprue Fm Models for the Axle)
Just Adults can do it ( Safe in First Place ) !
Step 5: Assembly ;
Cut & Bend a " Paper Clip " : Use it like a tool for insert the " money elastic band " into the Therea Sprool.
The sequencer : ]
A - The Smaller piece of the Paper clip ( like micro letter "C ") is the ( st ) one , it will be the " stopper "for Elastic Band.
B - With the micro "tool" insert the Elastic Money Band into the Thread Spool
C - Insert the Metal Washer ( 0,78 inch ).
D - Insert the (st ) slice of the " Wine Cork Slice "
E - Insert the ( nd ) slice of the " wine Cork Slice " with that lillte " Gap " with that little " ridged .
F - Finally inset the Axle ( wood stick barbecue - or sprue model cutted).
DONE !
Step 6: With Some Imagination ...paint Anything You Want ( Gouache Ink ) ...
...Enroll some " spins " ... and that's all ...
The Speed of the Our "Little Geek Turtle "can be set with -: The pressure at the "Money Elastic Band " :
More Pressure = Lower Speed ( like the Turtles )
Minus Pressure = High Speed ( ...rs , for a Tutlle ??? ).
