Introduction: Little Papercraft Steve
About: I came to Instructables because I absolutely love making things. The forms of craft I like the most are papercraft, origami, needlefelt, and doodling. I have a 3D printer too :D
This is a very simple tutorial on how to make this cute little Steve from Minecraft.
We will need:
Glue
Printer
Paper
Scissors
Toothpick (optional)
Yourself (not optional)
Step 1: Print the Template
First, you click on the image above, at the bottom left corner there should be a download button. Click that, open the file, and then print it. If you don't want it to be that small, just use some kind of editing thing and make it bigger.
Step 2: Cut Out the Template
Ok, now we cut out the template. This is pretty self-explanatory.
Step 3: Fold the Template
Now, we fold on the lines, including the tabs.
Step 4: Glue the Template
This is where it gets a little harder. You will need your glue and a toothpick would help.
With toothpick:
You should use liquid glue, then dip the toothpick in(try to wipe off excess), and put it on the tab. Fold the template together and hold it gently until it can stick on its own.
Without toothpick:
Use a glue stick or liquid glue, I would recommend a glue stick because it's less messy. Rub the glue stick or drip the liquid glue on the tab, and then fold the template together and hold it gently until it can stick on its own.
Step 5: Done!
Now it's complete!
