Little Red Guitar
Intro: Little Red Guitar
My 7 year old daughter has always loved pretending to be onstage giving a performance. For Christmas she's getting a child size guitar (along with this refinished one). This smaller version makes it easier to put on Taylor Swift concerts when she's running about.
Special thanks to my Mom for providing this miniature guitar. I refinished it red, polished the hardware, and replaced the strings.
STEP 1: Taking Off the Hardware
This part is pretty straight forward. I unwound the strings and took off the hardware. It was a little harder to remove the frets but my pocket knife made short work of it. I made sure to put all the parts in a plastic bag.
STEP 2: Sanding
To prep for primer I sanded the guitar down. I also used a file to file down some of the high spots on the neck. Before moving on I wiped off all the dust.
STEP 3: Gluing Up the Cracks
The fret board was coming off. There were also some cracks around the body. I used wood glue before clamping things back down. Here you also see the sheet of paper I stuffed in to keep paint from spraying inside.
STEP 4: Painting
First was a coat of primer. I wet sanded and reapplied a couple coats. Next was red paint. It's actually one of the factory colors for a Ford F150. Then I taped off the body and painted the fret board black.
STEP 5: Pin Stripes
I had pin stripping left over from a pinwood derby car. I thought it would work well here. It's easy to work with. Just peel off the backing and work it around the curves. The ring was made by placing painters tape on wax paper and curing out circles. After transferring the tape to the guitar I painted it black.
I sprayed paint on tin foil and dabbed a brush in to touch up imperfections.
STEP 6: Final Touches
I sprayed on a clear coat and wet sanded that too. I actually used metal polish to buff the finish. It worked well. Last step was to put all the hardware back on and tune it up.
8 Comments
MatinO 7 years ago
what do you need to maaake?
Admiral Johnson 7 years ago
Wow looks great!
Awesome little project
MrBillG59 10 years ago
You could have used Comet or Ajax scouring powder with water to rub-out that paint job. Try it some time, it works great.
emilkaram 10 years ago
mdtevans 10 years ago
moamenenoo 10 years ago
Assassin4627 10 years ago
paganwonder 10 years ago
