Introduction: Little Stand for Bracelets, Hairlooms and Watches
The main items are an old cd and an empty tube from effervescent vitamins. Other things that you need are:
- glue gun or any other glue
- old batteries
- colored napkins
- white base coat paint
- one small piece of cardboard
Step 1: Preparing
First paint the tube and the cd whit the white base and then use decoupage technique for applying the model of the napkin that you like.
Step 2: Glue the Cd and the Vitamins Tube
After the 2 pieces are well dried, you can stick the plastic tube onto cd. Then fill the tube to 2/3 of it or less with some old batteries (or any other thing that is heavy: sand, pebbles, etc.) to ensure that the loom-stand is stable.
Step 3: Covering the Filled Space
Cut a small circle from a cardboard (or even plastic sheet) that fits to the hole from the tube, and a little bit of glue on one side and push it through the tube until it touches the batteries. The cardboard cap will stick to the filling.
Step 4: Varnishing (optional)
At the end, if you want you can use some varnish to make it more shiny :D
Otherwise, you can use your new bracelete-loom-stand. On the top of it you can put tweezers, small hair clips or any other think that fits.
