Introduction: Live Edge Charcuterie Board
Simple instructions on how to make this live edge charcuterie board from an oak slab.
Step 1: Draw the Outline of the Board
Start by drawing the outline of the handle/curves on the board. Look around and use things with rounded edges to make them perfectly round (lids of cans, tape rolls, etc).
Step 2: Cut Out What You Drew
Step 3: Plane the Board
I then ran it through my planer.
Step 4: Sand the Edges
I then sanded the edges using these sanding drums. When they're put on a drill press, it makes sanding the edges so easy.
Step 5: Fill the Cracks
I have used this stuff a few times and so far, it's the best I've found to fill small holes/cracks.When paired with the accelerator that they make, you can sand in only 15 minutes!
Step 6: Finish Sanding
Give the whole piece a good sanding. I start at 80 grit, then go to 120, then 220.
I use this orbital sander and I love it as well.Step 7: Apply the Finish
I use Odie's Oil to finish it - it is food safe and smells so good!
