Introduction: Lizard Keychain
Here is an easy way to get rid of those spare pony beads you just can't get rid of because there some use for them your not thinking about. So let's get started!
Supplies( per lizard)
1 long piece of yarn/string
30 beads of your choice in color ( purple )
18 beads ( white )
2 black beads
Scissors
18 beads ( white )
2 black beads
Scissors
Step 1: The Nose
Put the bead in the middle of the yarn and pull the sides of the yarn so its equal.
Step 2: Start the Head
Attach two beads to the side that does not have a needle on it, then loop the needle backwards through the beads.
Step 3: The Neck
Put 2 black beads and 1 purple bead in the middle for eyes, then loop backwards and tighten. Then put 2 purple beads on the strand without the needle, and loop backwards into the 2 beads.
Step 4: The Arms/legs
Attatch 2 purple beads and 3 white beads. For this part only loop backwards with the same string and only through 2 purple beads, skip the white beads.tighten as close to the body as you can.
Step 5: The Body
Look at these pictures and copy the pattern of beads while looping backwards through the yarn
Step 6: The Other Pattern Pictures
You slowly decrease in #s of beads while making a cool white pattern on the back.
Step 7: Legs
Just do the exact same as you did with the other legs
Step 8: The Tail
Carefully attatch the single bead ( six of them )
To the body and tie a knot at the end. Your finished! Hope you enjoyed! Feel free to post pictures if you make this!
