Introduction: Sound Bending Machine - Intro to Circuit Bending
All credit goes to Dani Dögenigt on this build which happens to be my 100th Instructable!
I just want to take a moment and and give a massive shout out and a whole lot of thanks to Instrucables. What an amazing place to share ideas and connect with like minded people. It's allowed me to really expand my abilities and has given me an avenue to share a a bunch of projects with you all. Last but not least, I would like to thank anyone who has voted for me in a competition, you dudes rock!
Back to the project at hand... Whist traversing the hackaday website, I came across the amazing Dani Dögenigt and his website, which in his words "...documents the process of designing analog instruments and reverse-engineering vintage hardware + more". Part of his work is on circuit bending, which I wasn't very familiar with. For those like me who don't know circuit bending is, put simply it's hacking toys, vintage keyboards or anything which makes sounds to make unique sounds. You probe around the circuit, making short circuits to see what other sounds you can produce. Once you have a sound you like you can then add potentiometers, switches etc and create your own music and sampling machine.
The case comes from an old intercom that I had lying around. the great thing about these is they come in pairs so you can easily make 2 if you want.
check out this website if you want to get a crash course in circuit bending
The circuit I used is from a very cheapo voice recorder. Dani Dögenigt uses a similar one but is a lot harder to hack. The one I used is relativity simple to find sounds on and solder extra wires to. However, you do need some experience at soldering so if you are a beginner, this might not be the project for you.
Step 1: Parts
Parts
1. Voice Recorder - eBay
2. 4 X Momentary switches - eBay
3. 4 x Toggle Switches - eBay
4. 2 x Potentiometer 1M - eBay
5. 2 x knobs for potentiometers - eBay
6. Thin wire
7. 2 x AA battery holder - eBay. You could use AAA as well.
8. Audio input - eBay
9. Case to add the speaker, circuit board and all the bits into. You just use a project box or maybe something like a transistor or walkie talkie, or what ever you want really. I used a vintage intercom to house my parts in. I have also included some other case ideas in the images
***Ignore the solder board - I didn't use this in the end***
Tools
1. Drill
2. Dremel
3. Soldering iron
4. Pliers
5. Hot glue
Step 2: Adding a Battery
Before you can start experimenting and circuit bending, you first need to attach the battery to the circuit board.
Steps:
1. Locate the 2 points on the circuit board where to attach the positive and negative wires from the battery holder. 2. Solder on the wires to the circuit board
3. Place some batteries into the holder and test the sound recorder.
Step 3: Start Circuit Bending
Circuit bending is really quite simple. All you need to do is short circuit 2 connections on the circuit board. To make it even easier, most of the sounds I got from the circuit come from the IC so all you need to do is use a probe and touch the legs on the IC to see what sounds you can get.
Actually I've done all of the hard work for you so if you just want to use the connections I found - skip this step and go to the next one
How to make a probe
1. Grab a piece of wire about 200mm long
2. Next, solder on a couple of stiff wires to the ends of the wire. I used a couple of pieces of copper wire.
3. I also added some heat shrink around the solder joints just to make it a little stronger
That's it. You now have a probe to short circuit the IC
Step 4: Creating a Diagram
The below image shows how I wired all of the effects up to the board. You may want to conduct your own experiments to see what effects you can get out of the board.
Steps:
1. First thing I did was to get an image of the sound module, enlarge it and print it off. This way I can I can make sure I mark any good connections whist circuit bending
2. Next I started to experiment and noted any interesting sounds made when I used the probe. Once I found an interesting sound or effect, I marked it down.
3. After finding a bunch of effects that I was happy, I then created a mud map with all of the connections and parts that I will need. You can find this in the images below.
Step 5: Wiring the Circuit Board - the Rest of the Wires
Initially I started to solder the wire directly to the legs of the IC. This didn't work so I decided to add the wires to the IC solder points. I didn't take step by step images of all of the wires as it was just too hard to do. If you follow the diagram though you won't have any issues.
Steps:
1. Have the diagram in front of you and start so add lengths of wire to the reverse solder points.
2. Ensure that you don't bridge any of the solder points and take your time adding all of the wires
3. I thought adding some jumpers on a board would help but it didn't so I removed this and just soldered wires together where necessary.
4. Lastly, take your time and test continuously.
Step 6: Wiring the Circuit Board - Record, Play and the Microphone
You will need top add a couple of wires to each of the record and play buttons. Alternatively you could de-solder the buttons and add the wires to the solder points. However, leaving them in place allows you to test throughout the hack.
Steps:
1. De-solder the microphone from the circuit board.
2. Solder 2 wires to each of the solder points. One lot will be for the microphone and the other for the audio input jack.
1. Solder 2 wires to the solder point on the record switch. You will notice that there are 4 solder points. You need to attach the wires as per the image below.
2. Do this the same for the play button
Step 7: Adding the Switches, Speaker and Pots to the Case
Steps:
1. First you need to think about where you want to locate the switches and pots. Have a good think about it first before you start to drill and make the holes.
2. Secure your switches, pots etc to the case making sure that you will be able to get to the solder pints later
3. Add the microphone.
4. Add the audio input socket.
5. Next add the speaker. I just added a few dabs of hot glue to secure in place
Step 8: Soldering the Wires to the Switches Etc
Steps:
1. Place the circuit board into the case and decide how everything is going to fit. Also add the battery and ensure that the case closes. If everything closes up then it's time to attach the wires to the switches.
2. Measure and cut the wires to length. Tin the ends and attach them top the switches and potentiometers.
3. Make sure you test as you go a.long where possible. If you run into trouble, check your solder points and make sure nothing is bridged or come off the IC
4. Lastly close up the case
Step 9: Playing Around With Your Lo-Fi Sampler
First thing to do is to record a sound. Once you have added some sound it's time to start bending and sampling. The pots allow you to slow down and speed up the sound making for some cool effects. The distorter switch gives distortion and quieten downs the sound coming out the speaker. The restart button does just that, it restarts the sample.
Next plug in some music to the audio in and record some music to the sampler. This is a really fun way to mess around with your favourite song.
What next?
1. I wish I could have worked out a way to have an audio out. If anyone has any ideas, please let me know.
2. What other sounds can I get out of it. f you do build one and manage to get other sounds, please let me know what you did.
3. Cases. I sure that there are many other types of cool cases that this could be housed in.
4. The sound module only records 10 seconds of sound. You can extend this to 20 seconds by changing a resistor but the sound is degraded. Still might be a good idea to try.
5. The schematic of the circuit can be found here
Trash to Treasure Contest 2017
4 People Made This Project!
- Panther made it!
- mhaeg made it!
- lonesoulsurfer made it!
35 Comments
Question 1 year ago
Curious, would it work to replace the microphone with something lika adafruit FX board that loops the same track over and over ?🤔
Fantastic build btw, love it!
Answer 1 year ago
You can actually connect the circuit directly to an audio source as well so it could be possible.
Thanks for checking it out! I've actually done a couple other iterations of this build now. I've added links to them below if you want to check them out as well.
https://www.instructables.com/Sound-Bending-Synth/
https://www.instructables.com/LED-Sound-Bending-Ma...
2 years ago
Hi, glad it inspired you to replicate - of course the DIP IC is much more obvious for bending, if only I knew back when I did the original. Flimsy little SMD components!
There is something really appealing about lo-fi sampling. I used an arduino/atmega328 with WaveShield for a full scale sample player with sequencer(MicroWaveSampler) and a ATTiny for the worlds smallest and cheapest 16-bit WAV player for my debut album (elm-chan wav player)
Keep Tinkering!
Dogenigt
( dogenigt.blogspot.com )
Reply 2 years ago
It was a big inspiration - thanks for sharing it. Yeah those large DIP IC's made the job pretty easy in the end. I've built on the original idea as well and have added echo/delay and a amp which really gives it some kick. You can check out the Instructable here
Looking forward to seeing what you have been up to on YouTube.
all the best and thanks again
2 years ago
hi.. great work on the project.. i've been wanting to do this project since i first knew about the ic chip and i can't help myself on searching for the schematics and youtube more about it. on my findings i found a little problem that bugs me, you see on the loop-thingy mode there sort of a delay before the sample started to repeat itself, is there any workaround that? thanks
Reply 2 years ago
Yeah I noticed that too. Unfortunately I don’t think there is much that you do about it as it’s the way the chip is designed.
Reply 2 years ago
i have an idea.. sort of but i didn't know if it will work.. but.. what if we put an 555 timer chip as an signal to control the loop start? what's your thought on that?
3 years ago on Step 4
Cable color
Reply 3 years ago
B SIDE Cable Color
Reply 3 years ago
That's much better :) thanks for contributing
Question 3 years ago
Hey! Thanks for this instruction! Was really helpful for me. Right now I am building something with an Arduino and multiple ISD 1820. The Arduino is controlling the record and playback of the ISD 1820 and I made a breadboard patchbay with the connectors of the chips to experiment and do the circuit bending. So I also can interconnect the ISD 1820. All works really fine already but I got one question. Is it somehow possible to connect one speaker to all the ISD 1820? I tried to go from the speaker out to one speaker but it creates glitches that I don't want. Any hint? Here is a pic of the project how it looks recently.
Answer 3 years ago
Looks like a really interesting project! I like the idea of stringing ISD 1820 modules together.
The only way I can think of is to add capacitors to each out the outputs on the modules. This might help smooth out the glitches you are getting.
Good luck!
3 years ago
FF and Slow down: are they contradict each other? What green disturbance for?
thank you for you project!
Reply 3 years ago
no they don't really. if you have the slow on full then you won't be able to back it run quick and vice versa. The green button just adds a different type of sound
Having trouble connecting in external mic... Could connecting a speaker to the mic joints work? r you suppod to only use one side of the mic joints, as theres two
Answer 3 years ago
Sorry for the late response. You'll need to connect the mic up to the same solder points on the circuit board. The mic has a positive and ground solder points so you need to make sure that the polarities are right. try switching around the mic as you might have the polarities incorrectly connected
4 years ago
it sounds so good ! So bad it needs premium to look at details on pdf. Hope my friend can understand all this as is...
Reply 4 years ago
Hi! Everything that would be in the PDF is what you see here. The PDF is just the Instructable formatted for printing :) It does not contain additional information.
Nicole - Community Manager
Reply 4 years ago
Oh, ok, thanks !
I misundertood!
Reply 4 years ago
No problem!
