Lo-tek Remote Lightswitch/dimmer Control
13,225
23
20
Introduction: Lo-tek Remote Lightswitch/dimmer Control
Light switch too far across the room?
Hate it when you're starting to get it on and have to get up & walk across the room to dim the lights?
Impress the geek boy/girl in your life with your clever use of fly fishing line & a binder clip!
I actually came up with the basic design when i was 8 and terrified of turning off the lights before my head was under the blanket (because that's when you're the most vulnerable to monsters). This solved that problem also quite well, proving its usefulness & practicality for all ages.
Step 1: Collect Materials
You will need:
- an installed lightswitch (or, preferred, slide dimmer)
- 4 sewing bobbins (preferably with small diameter cores)
- 4 nails (with heads large enough that the bobbins won't fall off of them)
- a binder clip (optional; for the "non-destructive, non-adhesive" installation style *
- enough thin fly fishing line (preferred) or regular fishing line to complete a full path to your target location and back, plus up & down the walls.
  • You can alternatively drill through the light switch/dimmer to attach the line and save your binder clip for other exciting uses.
Step 2: Install the Bobbins
If you live in a victorian, etc. with wood trim high on the wall & wooden baseboards, bonus. They're perfect for mounting your bobbins.
Otherwise you may need to find studs in the walls or something else suitable to mount them to.
You want one bobbin mounted almost directly above the lightswitch, one almost directly below, and the other two bobbins directly across from the first two, at the place where you wish to have control of the switch; the bobbins should mark the corners of a square with the vertical sides passing through the lightswitch and through where you want to control the lightswitch.
The bobbins really don't need to rotate at all, as long as they're smooth enough to let the line pass around them without much friction.
Step 3: Attach the Binder Clip and String the Line
Attach the binder clip to the switch/dimmer. Tie one end of the line to the top, string it over the bobbin above the switch, over to the second bobbin, down, over, and back up. make it taut but not too tight, and tie the other end to the other side of the binder clip.
You may need to play with the clip with a pliers a little bit to de-springify the little levers (you ideally want the central clip to still be tight but the finger levers to be free to move without bouncing back into place; this will help keep the clip from spontaneously detaching from the switch/dimmer).
Alternatively you can tape, glue, or drill the lightswitch to better attach the line. Of course you should know what you're doing and how a lightswitch is put together and disconnect electricity or whatever's necessary to make it safe if you're drilling. Standard "don't be stupid" warnings apply.
Step 4: Enjoy Your New Sense of Liberation
Operation is pretty obvious. Move the line up and the lightswitch goes down and vice-versa.
Be the First to Share
    • Teach With Tinkercad Contest
    • Metal Contest
      Metal Contest
    • Crayons Challenge
      Crayons Challenge
    20 Comments
    chemkid42
    chemkid42
    8 years ago on Introduction
    This is great! I can't believe I never thought of this I guess cause I never had a dimmer.
    mwwdesign
    mwwdesign
    13 years ago on Introduction
    I did this when I was about 8 too! I also used some Lego bits...
    RGM La Paz
    RGM La Paz
    14 years ago on Introduction
    i did the same thing a year ago but with bendy straws and masonry string
    deansep
    deansep
    I have had that idea for a long time I just didnt figure out how to get the string on the switch. With my light switch its either tilted up when its on or tilted down when its off so the string would slide off. Think im going to try it. Good instructable either way.
    cooblades
    cooblades
    15 years ago on Introduction
    If I had a brother with this, I would reconnect it to set off some monsters. :-)
    dogsrcool2me
    dogsrcool2me
    15 years ago
    you got that idea from bill nye.
    trebuchet03
    trebuchet03
    Reply 15 years ago
    While possible.... Something tells me otherwise... Especially since the show went off air right around the time this person was born. I know it was syndicated for awhile, but it's been a long long time since I've seen it :P A pulley is a simple machine, as is a lever - both of which are not novel ideas of Bill Nye.... That, along with Beakman's World were may favorite shows when I was a little kid... You know, right up there with Ninja Turtles :P
    tymm
    tymm
    Reply 15 years ago
    actually i'm on the other side of the bill nye gap; the show started after i was in college... i'm more of the mr. wizard generation. if bill nye did a version of the same thing, cool -- but i haven't seen it.
    cooblades
    cooblades
    Reply 15 years ago on Introduction
    Bill Nye always scared me... no one could be that happy... something fishy was going on. A rat however, you can always trust to be a rat so I could trust beakman's associates.
    trebuchet03
    trebuchet03
    Reply 15 years ago
    fair enough :P hehe, that was a rather big assumption I made :D
    paulgeering
    paulgeering
    15 years ago
    Ever wonder that the monsters might come along and cut the line? :-|
    CameronSS
    CameronSS
    Reply 15 years ago
    use Kevlar.
    Sk8rDuck
    Sk8rDuck
    15 years ago
    Cool! I used to have a loft bed and I cant climb up it when its dark to I tied a string to the lightswitch hanging down, looping around the bottom of my bed and coming back up to me. This looks like it stays on better :)
    trebuchet03
    trebuchet03
    15 years ago
    Very Rube'esque :P And totally Ferris Bueler! You deserve a day off for this :) I might actually make this if I have the parts :P You know, just for fun... And put a nice handle on the end :P
    Punkguyta
    Punkguyta
    15 years ago
    This is pretty neat. I've always wondered about doing something when I was younger (yes the monsters under my bed thing).
    Robyntheslug
    Robyntheslug
    15 years ago on Step 3
    _ This reminds me of building 'burglar' alarms and traps to catch my little sister at things when I was that age.
    Wonder if it works on conventional on/off switches?
    crapflinger
    crapflinger
    15 years ago
    it's a known fact that the moment your toes are under the bed when you're getting in...is the moment that you're most vulnerable to monster attack...well...at least under-the-bed-type monsters...they tend to feed on toes... for all those suggesting a clapper...pffftt...what's the fun in that? LOW TECH IS THE RIGHT TECH...
    LasVegas
    LasVegas
    15 years ago
    Cut the line at some point and tie into it an extended spring from an old ink pen. This would help keep the line taut throughout.
    tymm
    tymm
    Reply 15 years ago
    Good idea -- with the fly fishing line I used it's got plenty of springiness and the tension is great... but a spring would certainly allow use of other materials for the line (probably would help if using regular fishing line).
