Introduction: LoRa Radio Wireless SX1276 862-930MHz 915MHz UART Serial Module Transmitter Receiver
This tutorial utilizes the LoRa (Long Range) protocol, operating on a frequency range of 862-930 MHz, leveraging the SX1276 RFIC from Semtech. With a specified range of 3 kilometers, this technology is inexpensive and practical for my outdoor robotic projects that demand reliable, long-range serial communication (UART) but at lower bandwidth.
Step 1: Wiring to Configure the Lora
For each pair of Lora (left) and FTDI (right):
- GND -> GND
- VCC -> VCC
- TXD -> RX
- RXD -> TX
- M0 -> VCC
- M1 -> VCC
Steps to configure the Lora:
- Connect the FTDI to a computer USB port.
- Download the software: https://www.ebyte.com/datadown/943.html and search for "E32". When this tutorial was written, the latest version was version V4.7
- Select the serial port number and click "OpenPort", see the 4th picture. You can find the correct port number from your Device Manager.
- Click the "GetParam" button and the Lora existing settings will be displayed.
- Modify the settings:
- UartRate: this the serial baudrate to interface with an external device (e.g. Arduino)
- For this tutorial, we'll use a fixed transmission setup with: Address: 0 Channel: 6 This configuration establishes a point-to-point communication link.
- In the future if you want to set up a separate pair, set the pair to different address and chanel to prevent interference.
- Click the "SetParam" button to save the settings.
- Repeat step 1-5 above to the 2nd pair of Lora and FTDI.
The link to the Lora user manual, including how to set it up in a broadcast mode.
Step 2: Test the Wireless Communication
- Connect the Lora M0 and M1 to GND. Do this to both Lora modules.
- Connect the FTDI to a computer USB.
- Open any serial terminal app, in my case I use the Arduino IDE
- Select the port, in my case COM23, see the 1st picture.
- Go to Tools->Serial Monitor, see the 2nd picture. Set the baudrate to the Lora UartRate from the previous section (when Lora was configured).
Repeat the step 1-5 above to the 2nd pair.
- The third picture illustrates two separate Serial Monitor windows, displaying data from two pairs of devices: one connected to COM23 and the other to COM10 in my case.
- Test wireless communication between the two LoRa devices by typing a message in the Serial Monitor's input field and clicking 'Send'. This enables bidirectional communication, allowing you to exchange messages back and forth
Step 3: Wiring to External Devices
Both LoRa devices are now configured and ready to establish wireless serial communication
- The FTDI are no longer needed.
- Connection from Lora (left) to an external device serial (UART):
- TXD -> RX
- RXD -> TX
- VCC -> 3.3V
- GND -> GND
- Repeat step 1-2 to the 2nd external device:
- Wireless connectivity is established between the two devices.
