Introduction: Lockable Secret Door in MCPE
hey guys, in this instructable I'm going to show you guys a semi-lockable secret door in Minecraft pocket edition!
Step 1: Find a Space
Find a flat space beside your stairs (that go down). Make sure there is one block between the stairs and the nearest edge of your flat area.
Step 2: Dig
Dig one block in three blocks up/down then at the bottom break the block between the stairs and the hole.
Step 3: Place
Place a door at the bottom, then above it a sign.
Step 4: Placing and Breaking and More Placing
Now go to your stairs. Place an upside-down stair (make sure you can still see the door),
Repeat this all the way down the stairs except with out the door, instead use oak wood planks
Step 5: Add the Room, Place the Painting
Dig out and furnish your secret room. outside, put a painting over the wall covering up the door and sign.
Step 6: All Done
Now your friends cant steal your prized jewels, well unless they go around breaking everything.
Things not to do:
• place a door on the same level as the painting; doing this would make the painting break when you close the door.
• create a huge amount of light near the stair that covers up your door; doing this would make the door glow making it easy to see.
Things not to do:
