Loft Beds With Bookshelf Ladders
Intro: Loft Beds With Bookshelf Ladders
My daughter has always had her own room, but envies her brothers' bunk bed. So I built her a loft bed that look likes a floating cloud, which made her happy and created a little more space in her room. It uses some of the design principles of the one-legged bunk bed I posted previously - namely using the walls as part of the frame. However, this one has a heavy duty combination ladder/bookshelf for support, rather than a single leg. It's built using simple joinery out of construction lumber (2x4 and 2x6) and plywood, it's incredibly solid, and it only cost about $150 to build.
And pretty much as soon as I'd built that one, my eldest son moved into a room of his own... and wanted a loft bed, too. His incorporates a second bookshelf, a desk, and a secret compartment, and is designed for someone with longer legs, more books, and who isn't fussed about sleeping on a cloud...
Note: $250 wooden commercial loft beds
STEP 1: Design: Loft Bed #1
One end of the cloud loft bed (from here on in, #1) is a combination ladder/bookshelf. It's angled at a 4:1 ratio, which equals 14º away from vertical. It has six steps and six shelves, and can hold nearly three linear meters (10') of books. The bed is about as high off the ground as it can be and still retain head room above, with 8' ceilings (important so the occupant can sit up in bed).
The side of one of the beds is a stylized cloud. It's pretty cute for an eight-year old, but I have no illusions that a teenager will necessarily think it's just as cool, so I anticipate removing it and replacing it at some stage with some other design. The ladder and bookcase are pretty future-proof, I hope - it's quite comfortable for an adult to climb, and we all need storage for books.
Click on the icon below to download the SketchUp 3D design file for this loft bed, and use it as a starting point to design your own.
STEP 2: Design: Loft Bed #2
The other loft bed (#2) has a mitered railing instead of a cloud, and because it's going in a bigger room, has space for a desk and another bookshelf alongside the bed. It's also covering a redundant fireplace, which gives the opportunity for adding a secret compartment. NO ONE is too old or too cool for a secret compartment, unless they're dead inside.
Other design differences: it has 5 steps instead of 6, as my son is over 5' tall at age 10, and will probably be 6'5" before leaving home (uh-oh...). Wood strips instead of plywood backing for ladder bookshelf - just enough to stop the books falling off the back. No bottom shelf. Dowel running underneath bed, so the space can be used as a wardrobe. The bed frame is notched into only the wall side of the bookshelf ladder - it is lag screwed into the inside of the outside leg. This allows the 2x6 on the outside to look seamless (the other bed didn't need this, because the plywood cloud performs that role).
STEP 3: Tools and Materials
This project will be easier if you have access to a miter saw
You need (for each bed):
3-4 pieces of 10' 2x6 construction lumber (carefully selected)
3-4 pieces of 10' 2x4 construction lumber (carefully selected)
3" deck screws
1/4" plywood, about half a sheet
5/8" plywood, construction grade, one sheet
5/8" plywood, sanded one side, one sheet
4 1/4" x 6" lag screws with washers
Wood filler
Paint
For the additional bookcase for #2 - I used three 10' 2x10s. You need some more 2x4 for the legs and sides of the desk and a small piece of plywood (5/8" or thicker) for the desktop.
Price is a little hard to judge, because I had some materials already. I'd ballpark $150 for each bed - the extra plywood for the cloud bed was compensated for by the extra wood for the additional bookcase/desk for the other bed. If you need extra plywood to cover up a fireplace like I did, that will add another $50.
STEP 4: Cut Boards
Cut these 11 pieces with square ends:
5 x 400 mm, 5 x 486 mm,1 x 962 mm
Cut these 3 pieces with parallel ends at 14 degrees:
1 x 1900 mm, 2 x 1462 mm
Saw the 2x4 to the following lengths, all with square ends:
2 x 2032 mm, 1 x 1200 mm, 2 x 964 mm, 1 x 362 mm, 1 x 162 mm
Cut six pieces of 1/4" plywood to 250 x 486 mm, and cut some of the good 5/8" plywood into six strips 20 x 486 mm. Fill all the holes and imperfections in the lumber with wood filler, and sand. You're ready to assemble the frames.
Note: check these dimensions will fit your mattress! The design could accommodate a bigger mattress (double, queen, king) no problem, but you might like to use 2x6s in place of the 2x4s in the frame. Bonus: you'd get a much wider bookcase! There are slight design changes for the loft bed #2, but from here on I'll just describe the cloud bed (#1), for simplicity's sake. The construction is also exactly the same for both. Check the plans for the details.
STEP 5: Assemble Ladder/bookcase
Make cut-outs (using jigsaw or saw + chisel) for the 2x4 frame in the back of the 2x6, 55 mm deep at its deepest point, at the underside of the top step.
Add the strips of 5/8" plywood to the underside of the 486 mm long pieces so you can support the backs of the shelves; 55 mm back from the rear of each shelf. Attach with wood glue and brad nailer. The backs of the shelves are made from 1/4" plywood, and can be fixed in place, nailing into the back of each 2x6 and into the plywood strip from the front.
Fill the screw holes, nail holes, and any other imperfections with wood filler, and sand smooth.
STEP 6: Assemble Bed Frame
STEP 7: Paint
STEP 8: Install
Measure the plywood base for the mattress and cut to fit. Screw it to the frame.
STEP 9: Clouds (or Railing)
The other bed has a piece of 2x4 that joined up to the other bookcase. Utilitarian, but easy and with a nice miter and rounded edges (I used a roundover bit in my router), it looks good.
STEP 10: Side Bookcase and Desk
STEP 11: Clothes Rail
STEP 12: Secret Compartment
Who doesn't want a secret space in their room? This one was easy to make, because we were covering up an open fireplace (which is perfectly functional, but which we never use - the room is way too small to justify it). All I had to do was make one of the plywood panels removable. You lift the panel up and over a strip of wood to remove it and reveal the space.
STEP 13: Add Bedding, Books
...and happy occupants, and you're done.
STEP 14: Builds
Happily, lots of people have made beds according to these plans, and nearly all of them who were kind enough to provide photos made slight changes. Check them out for further inspiration. Many thanks to benjamin.burton.9887, burgzt, ChiDoug, instructablesdstark, mitch.duke, ndnfld, sfsavage, yuravgjoe, AndreasM3, GregV9, MarcelS9, and GarthM7 for posting photos. And also check out the "I made it" section below - a ton of additional variations on the theme.
167 Comments
sunydayz 1 year ago
makendo 1 year ago
priy940146 3 years ago
kmem4noley 4 years ago
makendo 4 years ago
chadturner274 4 years ago
Love the plan. I want to go higher and allow for desk underneath the bed. Have you done that at all?
makendo 4 years ago
MorganB5 5 years ago
makendo 5 years ago
makendo 5 years ago
Not quite - it means 10 feet long (approximately 3 m), and with unfinished dimensions of 6 inches and 2 inches. This ends up being more like 5.5 inches by 1.5 inches.
Handy_Bear 6 years ago
Well, you finally made it to the homepage :P
makendo 6 years ago
ha, yeah it does look like it took a while, but I'm happy to report that it's not the first time
instructablesdstark 9 years ago
Looks great, do you think it would work to mount straight legs on the head end to make the bed free standing. I'm thinking a 2*6 mounted flush under the bed frame or flush on one side and outside on the other.
benjamin.burton.9887 9 years ago
I did exactly that. I used 2x8 and extended them above the bed to create a headboard shelf area. The bed was pretty sturdy without mounting it to the wall, but did have some movement in it, so I ended up mounting it to the wall, though I probably didn't need to mount it as well. I will add a few images also.
PeteS85 6 years ago
I know this is a 3 year old comment, but benjamin.burton.9887, do you happen to have your plans that you used? I am planning on using your headboard idea and incorporate some of my own, but between you and makendo that is a fantastic plan and bed(s)!! I need to make a freestanding bed...I am also going to incorporate a lienear desk (should also help with stability)
makendo 9 years ago
Sure, but without bracing it will wobble... so you will probably end up screwing it to the wall anyway.
AlessandroP47 7 years ago
is it possible to accomodate this project for a 3mt x 1.13 mt very small room? :\
dragon flyer 6 years ago
Long ago, I built a loft for my daughter in what was intended to be a storage room - but she needed a door way more than a window... It exactly fit a 4 foot sheet of plywood with two feet cut off it, leaving space to open the door into. I built plywood supports for the closed end and the corners. Her mattress left just enough space for a small set of shelves for storage beside the head end. It had a desk, bookcase, and dresser underneath.
I designed it so she could stand upright underneath it, but by the time I got it built she'd outgrown that...
julianwhettam 7 years ago
See my response above
PiperM4 6 years ago
This bed will fit perfectly in our tiny room if we don't put the ladder/bookshelf at any type of angle. If it would be at any type of angle it would make the closet inaccessible. Do you think I could do this same design but make the bookshelf/ladder 90º/straight up and down. I know it makes it a little harder to climb but my kid is a climbing master so I am not worried about that. But structurally would it still be sturdy without the incline on that side?
