Introduction: Logic Gates
Hello! friends
Welcome to my another Logic gates project. Its also the topic of Digital And Logic Design by Morris Mano (fifth edition) with the help of this project you'll know how logic gates works in reality.
So let's get started.
Step 1: Circuit Diagram
With the help of this diagram we can build our logic gates project very easily.
Step 2: Components
Already components mention in a previous diagram but something i wanna share with you. In this project i'm using only 1 bit for each IC's as a manually like (0/1) and other bit is already active for all IC's so that's why i'm using only 7 spst but you can use it 12 spst and you can control each bit as a manually.
you'll need
IC's: lm7805, 74ls08 (AND), 74ls00 (NAND), 74ls32 (OR), 74ls02 (NOR), 74ls86 (XOR) and 74ls04 (NOT) with bases
Switches: spst x 7
Resistors: 1k x 7
Led's: Red x 7
Vero board
Some jumper wires
Step 3: Component Placing
Place your components on a vero board and then soldering it.
Step 4: Soldering
Soldering your logic gates components very nicely and make some connections with jumper wires.
Step 5: Finish
Then it's look like this now enjoy your own dld logic gates project. Connect your 9 volt battery and push the power button on and it's ready to use. Small video in next step about logic gates which will clear your concepts.
Step 6: Video
Logic gates small video.
