Introduction: Logitech MX1000 Extra Button Mod
Back in the early '00, I got my Logitech MouseMan Dual Optical. This turned out to be the perfect mouse for me: the shape fit my hand, it was optical and it had good buttons. Especially the thumb button. I used to play alot of Aliens vs Predator back then, playing alien, and I had a huge advantage. I mapped the wall-crawl to the thumb-button, so I had complete control over movement from the mouse. And it showed in the statistics at internet cafés. Fast forward 3 years, and it died. I fixed it on several occations, but the optics sucumb in the end. Not long after, Logitechs first Laser-mouse was released, the MX-1000. Expencive at the time, but the familiar shape sold it for me. It became my new main mouse, and it's still on my desk.
7 years later, the battery was dead. No more charging. I found several guides on how to change it, and now it's like new again. While looking inside, I realized there was one thing missing: The thumb button I used to love. So I started planning. Sadly, I didn't take pictures while I was working, but I have some pictures that prove the concept, and a few things I had to deal with. I also have some plans for making it better.
Opening the mouse it pretty straight forward, four screws, two under the label, and two under the back pads. There are lots of guides on how to do this, and I'll put up some links later on.
The MX1000 is mostly seperate modules inside: The scrollwheel and buttons, the sidebuttons, the optics and the battery. I was interested in the sidebuttons, so first I removed the battery, as it is blocking the access. Next I pulled the tap back, and the button pcb slides out. On this pcb there are 3 buttons: Back, Forward and task selector. I use the back-button all the time, but because of my short finger, I never use the forward button, so I decided to piggyback on this one. I solder on the wires, and didn't measure any length. This came back to haunt me later.
Now it was time to make room for the button. I drilled a 4mm hole at the place the thumbrest was most worn, as I figured that's where my thumb was the most. Bingo, perfect placement. I then filed it to a square, so the regular pcb button would fit snuggly. I tried several different buttons to find the correct length, and ended up with a 7,2mm heigth. I didn't glue it in place; as I plan to replace it with a better button-top later, I just pressed it in for now. Soldered the two wires to the forward-button, and assembled the mouse. Testing worked, but the scroll-wheel didn't work for the left/right-clicks. Dissasembling the mouse I could see the wires were in the way, so I cut them to perfect length, and now it all worked.
Parts needed:
Screwdriver
Solder
Soldering iron
Push-button
Wires
Drill
Parts needed:
Screwdriver
Solder
Soldering iron
Push-button
Wires
Drill
