Introduction: Long Exposure Photography
In this instructable I will show you how to 'draw' with light, using a camera and lights.
Also how to have one person appear twice in a photo graph with out editing the photo
A Camera (One that can has a blub setting or can do long exposures)
Lights (I perfer LED's but it all depends on the picture you want)
Flash (Optional depending on the photo. Must have a flash for the second half on the instructable)
Step 1: Find the Correct Setting
Depending on the camera you can use different settings.
SLR:
For my camera the Canon 10D all I have to do is change my shutter speed to BLUB or have it be longer then 1/20th of a second (The Shutter speed also depends on how much light you want to allow in. If you want to "draw" a lot with the light then set your camera to a longer exposure setting, if you want a smaller "drawing" set you shutter speed faster. Its all about experimentation though, so mess around a little)
Point and Shoot:
All Point and Shoots are different look up in your camera's manual to find out how to set your cameras shutter speed. If there is no way to do that by your self try covering up the lense with you hand and turning off the flash. Focus and meter dont click the shutter yet. Once the Aperture and focus has locked remove your hand and take your picture. It should of set your shutter to the slowest it can since your hand was over your lense.
SLR:
Point and Shoot:
Step 2: "Drawing"
Now you can draw all sorts of images with your camera. If you have your camera on a tripod (recommended) then click the shutter move yourself (or a friend) in front of the camera with your light source and move the light around just to see how it comes out..Now that you have messed around a little its time to try a little more advanced techniques, try writing your name with the light. To do this click the shutter move into the frame of the camera and write your name backwards (its backwards so its frontwards to the camera). The Photo for this step was taken using Blub and then my friend wrote the words Sugie with a lighter.
Step 3: Experiment
Now Go out and try different tricks theres nothing wrong with just messing around. Try it with different lights try doing it with LEDS then bigger lights such as those on cars. Then try different colored lights. Have fun
The Photo for this step was of my drum machine. I set the camera for a longer (than normal) exposure (1/15th of a second) I rotated and zoomed in at the same time to create the effect like the light was coming towards you and rotating so have fun mess around with long exposures!
Try also if you have a subject you would like to have in focus and clear but still want to 'draw" with other lights try setting up a flash and still using a long exposure. So then once the flash goes off you can draw like you normally would. This is showed in the second photo of this step
Step 4: Doubles
Doubles are actually really easy. All you need is a tripod a flash and the BLUB setting on your camera. Set your camera up on a tripod and position your subject. click your shutter and shoot of the flash, while still taking the picture have you subject move to another position then shoot the flash of again. This should create an image with one person but 2 different positions.
**This one is best if done at night**
