Introduction: Loom Bow Ring
This is a really cute accessory that has many uses. It can be a charm, a hair accessory, a ring, and a lot more! I got this design from a channel on. YouTube called tutorialsbya. I forgot how to make it so I think I did it a different way, but I used double bands instead of single bands. This is a very simple charm, so anyone with rubber bands, a loom pick or crochet needle, and look can make it.
Step 1: Gather Your Materials
For this charm, you will need...
-Rubber bands
-Loom
-loom pick or crochet needle
-s-clip or c-clip
-Rubber bands
-Loom
-s-clip or c-clip
Step 2: Let's Get Started
Like I said, this is very easy to make. In the two picture on top, I am using single bands. These are my holding bands. Try to choose sturdy ones. For the rest of this tutorial, you will use double bands. The steps are all shown in the pictures, so follow the pictures and instructions will be provided for the more complicated parts.
Step 3:
Step 4:
Step 5: Cap Bands
Now we will place cap bands. On the right side, take a single bands and loop it around the peg shown 3-4 times. Repeat this process on the left side of your loom.
Step 6: Start Looming
Now you can begin the whole looming process. On the right side, go into your cap band and grab the top two bands. Those bands will go to the middle, as shown.
Step 7:
Step 8: A Little Confusing
Now its part is a little tricky. Look at the picture. Go into the bands and grab the bands that will go left. It's a little hard because you may grab the wrong ones. So be careful. There are a few more steps like this one, so be careful.
Step 9:
Step 10:
Step 11:
Step 12:
Step 13:
Step 14: Single Bands Only!
For the ring part, use single bands.
Step 15: Through
Put your loom pick or crochet needle through the bands you tied around the middle of your bow. Then pull a single band through those bands.
Step 16: Transfer
Transfer the bow to your loom as shown.
Step 17: Cap Band
Now you're going to add another cap band. Wrap it around the last peg 3-4 times.
Step 18:
Step 19: Wear and Enjoy!
Now you can enjoy your ring! Sometimes I use these as hair accessories, rings, charms, and pencil huggers! Thank you so much for viewing and enjoy!
