Introduction: Loom Cat Charm
So I got a request for a cat from Abigail02, so thanks to her, this 'ibles was possible! She has an amazing profile and some great Instructables, so check out her profile! Anyways, today I'm going to hopefully show you how to make this super cute cat! It's pretty simple and if you have made my Pickachu, then this will be very easy=) Enjoy!
Step 1: Gather Your Materials
For this charm, you will need...
•Any Loom
•Loom Pick or Crochet Needle
•Loom Bands Of Any Color
•Any Loom
Step 2: Holding Band
During this tutorial, you will be using double bands. So take double bands of your main body color and place as shown.
Step 3: Placing Double Bands
Now place the bands as shown to create the cat's face.
Step 4: The Neck
Place double bands as shown to make the neck.
Step 5: The Shoulders
Place double bands as shown to create shoulders for your cat.
Step 6: The Kitty's Tummy
To make the cat's stomach, you will need two colors: your main body color and your second body color. Place double bands as shown.
Step 7: The Cat's Legs
Place double body colored bands on both sides of your loom for the cat's legs.
Step 8: Arms
Now place double bands as shown for arms. Then twist a single second body color for the paws around the pegs shown four times.
Step 9: Ears
Take a single band and twist it around the two pegs shown once, creating two layers. Do this to the opposite side. Then twist a single second color band around the pegs shown four times.
Step 10: Horizontal Band
Step 11: Another Horizontal Band
Step 12: Three More Horizontal Bands
Step 13: Bottom Band
Follow the pictures to see how to fix up your cat's bottom.
Step 14: The Eyes
Without going into any bands, grab the eye bands and hook them over the peg as shown. Repeat this process for the other eye.
Step 15: The Nose
Take a single light pink band and wrap it around your hook three times, creating four loops. Then slide this onto a single body color band and place as shown.
Step 16: The Tail
Wrap a single band around your hook three times. Then slide this onto two bands. Loop it over and slide this onto two more bands. Continue until your house is long enough.
Step 17: Starting to Loom
Follow the next steps to learn how to loom your cat.
Step 18: Middle
Step 19: Arms and the Left Side
Step 20: Under the Tail
Step 21: Under the Arm
Step 22: Right
Step 23: Neck
Step 24: Beginning the Face
Step 25: Middle
Step 26: Looming the Ears
Step 27: Oh No!
If one of your bands break, that's okay because you doubled the bands! When you remove the cat, you will not be able to see the mistake.
Step 28: Left and Right
Step 29: Holding Bands
Loom forward your holding bands. Then you will see two layers. Loop the bottom layer over the top layer and tug.
Step 30: Remove and Fix
Your cat will be a little bit messed up at first, but tug and pull and it'll be fixed=)
Step 31: Tada!
Now you have an adorable little cat charm! Thanks again to Abigail02 for requesting this! If you would like to request a tutorial, please leave a comment! Thanks for viewing!
