Introduction: Loose USB Cable????
Do you have a loose USB cable? Here I have a solution to that problem.
Step 1: Problem
What if you charge your phone the whole night and it is still not charged, because off a bad connected USB cable? yes, well you day will be ruined!
Step 2: Equipment
Equipment:
- A knife or a needle, something with a thin point.
- The broken USB cable.
- A phone with micro USB connector.
Step 3: The Culprit
The small pins are for locking your cable to your phone. By using the cable a lot after a certain time the small pins will not connect your phone and USB cable properly enough.
Step 4: Solution
Use the small point en pull the two pins a bit. When this is done the phone still charge good without bad connection of the USB cable!!!!!
