Introduction: Low Poly Wooden Wall Art
Inspired by https://www.instructables.com/id/Tessellated-Wooden-Art I made a low poly picture of a hummingbird.
Step 1: Things You Need
Materials:
- piece of plywood (mine was 12mm sheet)
- scrap piece of wood or plywood for the background
- spray adhesive or any other glue to attach template to the plywood
- paint
- wood glue
- super glue
- wall hanging hardware
Tools:
- printer
- saw (I used a scroll saw)
- sanding paper
Step 2: Cutting the Template
printed an image of a hummingbird on two sheets of paper and glued them on a 12mm plywood. I cut each triangle out with a scroll saw. While doing so, I numbered each triangle on the printed image as well as on the underside of the wooden pieces.
Step 3: Painting and Glueing
I lightly sanded and painted each piece before starting to glue them onto the wood board. Because the pieces were very small, I couldn’t use any clamps; instead, I applied wood glue along with a bit of super glue to hold the pieces in place while the wood glue set.
Step 4: Final Product
All in all, I am pretty happy with how my little project turned out! Though, if I were to do it again, I would definitely use a larger mesh size, since some pieces were so small that I had to use tweezers while placing them down.
