Introduction: Lumpy Space Princess
Make the princess as a puppet
Step 1: Gather the Materials, and First Step
FOam (like 1 inch wide)
adhesive for foam
two pieces of wire
one marker
scissors
utility knife
First step
Using an existing image of LSP, make a cardborad template slightly larger than the original. Fold the template and cut both sides at once to get simetry
adhesive for foam
two pieces of wire
one marker
scissors
utility knife
First step
Step 2: Mark Two Arms Too and Cut the Foam
Mark the arms.
Cut with scissors the foam as straight as possible
Step 3: Put the Adhesive on the Thickness
And let it dry for a minutes
After its dry, joint the parts by pinching it, make this with the body and arms
Step 4: MAke the Details
Make the hand by the same method, start by putting some adhesive, let it dry, then joint by pinching both sides. To make the fingers mark the gap between with the marker and do the magic with your scissors.
Let the bottom part open to put your hand inside of it.
Put the wire inside the arms and mark were put them on the body. Let the adhesive dry...
Step 5: NOw Its Time to Dye
put half a jar of paint diluted in some water.
Put the Princess on her royal bath and squeeze the excess of water
(at the first picture: i tried to cover the surface before the coloured bath, but purple water leaked too )
Step 6: Finishing Touches
Paint the yellow star, the eyes and the eyebrows
You can use this princess as a puppet too
