Introduction: M2 Black Metal Chassis Mecanum Wheel Robotic Car Kit for Arduino Mega2560 DIY
About: Osoyoo brand products are mainly focused on STEM education.User experience and customer feeling are always our first priority. Our goal is to create the best designed product to help students and hobbyist to e…
Introducing the Future of Mobility: Unleash the Power of Mecanum Wheels with Our Omni Direction Robot Car Learning Kit
Discover a new era of robotics innovation with the OSOYOO Omni Direction Robot Car Learning Kit, featuring cutting-edge Mecanum wheels – the ultimate breakthrough in omnidirectional movement technology. Mecanum wheels, often referred to as omni wheels, redefine the way robots navigate by offering a hub with rollers aligned at a 45° angle to the axis of rotation. This groundbreaking design empowers our robot car to move with unprecedented agility and versatility.
Unveiling the Science Behind Mecanum Wheels:
Our Mecanum wheels are equipped with integrated rollers that move independently and passively. By controlling the rotation of these wheels in various directions, our Omni Platform becomes a true marvel of mobility. Seamlessly glide forward, backward, sideways, diagonally, or even spin in place with unmatched precision. Say goodbye to limited movement options and embrace a new era of robotics exploration.
Mastering the Art of Maneuverability:
Tight corners, narrow lanes, intricate pathways – nothing can stand in the way of our Omni Direction Robot Car. The unmatched range of movement offered by our Mecanum wheels guarantees efficient navigation across any environment. Navigate your creations through the most challenging spaces effortlessly, with a level of control that leaves traditional vehicles in the dust.
Designed by Visionaries, Crafted for Learners:
Developed by our team of visionary engineers from Japan and Canada, the Omni Direction Robot Car Learning Kit is the pinnacle of Arduino-based robotics education. Seamlessly control your creation via Bluetooth remote, explore the IoT realm through Wi-Fi connectivity, master line tracking, and embrace obstacle avoidance auto-driving. This kit is a comprehensive platform that equips you with the skills to thrive in the world of robotics.
Empowering Learning, One Kit at a Time:
The kit includes the OSOYOO Mega2560 board, fully compatible with Arduino Mega2560, and the OSOYOO ESP8266 Wi-Fi Shield. But that's not all – we're committed to your growth. Our meticulously designed step-by-step lessons ensure that even beginners can grasp the essence of Arduino robot programming. For those seasoned in the realm of DIY and Arduino programming, the kit's open-source code and hardware provide a launchpad to create remarkable projects of your own.
Elevate Your Journey Today:
Embrace the limitless possibilities of omnidirectional movement and robotics innovation. The OSOYOO Omni Direction Robot Car Learning Kit with Mecanum wheels is your gateway to unlocking the future. Gain the skills, experience, and confidence to embark on a journey that reshapes the world of robotics, all while having the time of your life.
Are you ready to move in every direction imaginable? Explore the future of robotics – because with Mecanum wheels, the path is yours to define.
Packing list:
Metal bottom chassis x1
Mecanum wheels x4
Metal gear motor with cable x4
Motor holder x4
Motor coupling x4
Acrylic upper chassis x1
Mega2560 board and cable x1
Uart Wifi shield x1
Model Y motor driver module x1
Bluetooth module x1
Tracking sensor module x1
Servo motor x1
Ultrasonic sensor x1
Mount holder for ultrasonic sensor x1
Voltage meter x1
18650 battery box x1
18650 battery x2
Battery charger x1
Electrician Tape x1
10Pin jumper wire male to female 20cm x1
3Pin female to female jumper wire x1
6Pin male to female jumper wire x2
7Pin female to female jumper wire x1
2Pin 20cm XH2.54 female jumper wire x1
Philips screwdriver x1
Hex wrench x1
Screws Package x1
Step 1: Basic Robot Car Assembly
Step1. Install the metal holder on metal chassis with 16pcs M3.5*12 screws, M3.5 rubber rings and M3.5 nuts as following pictures.
Step2. Installing 8pcs M3*6 screws as per the following red box.
Step3. Install the jack screws on Al-alloy coupling, please tighten jack screws to fix the Al-alloy coupling on motor as following pictures.
The shaft from the motor has a flat area on it. Make sure that the jack screw was positioned on this flat, and tightened both screws on the shaft as following pictures.
Step4. Install the 4 Mecanum wheels on al-alloy coupling with 4pcs M2.5*10 as following pictures.
For more information, please visit the following link:
Video Link
https://osoyoo.com/manual/202000600-m2.html
PDF Download Link
https://osoyoo.com/manual/202000600-m2.pdf
