Introduction: M72 LAW TagInn Airsoft Launcher ($70 DIY Build)
This is a TagInn launcher (M72 variant) for Airsoft & Paintball. This video shows you how to assemble the components for the TagInn Launcher. All 3d printer files are located here for you to use. Please be safe when assembling this project, CO2 is a dangerous compressed gas when handled improperly.
Step 1: Build Process for TagInn M72 (WATCH THE VIDEO!)
This is a summary of what is shown in the video. Please download and print all 3d .stl files first! Watch the video tutorial and if you have any questions, let me know. Be safe and enjoy! If you liked this tutorial and want to help me continue developing concepts, please donate. Please Donate THANK YOU!
1. 3d Print all files & clean up edges (light sanding)
2. Test fit large components (sand if needed)
3. Cut ABS pipe 12” (11” and 13” sections)
4. Notch ABS Pipe for Gas Shell (1-1/2”x6” notch approx. ½’ from end)
5. Assemble grenade shell holder
6. Replace gas valve on TagInn Shell
7. Test gas fill valves and line for leaks (SAFELY!)
8. Install grenade retainer 2
9. Install top screws on Pegasus section
10. Install gas valve mount
11. Build grenade trigger assembly
a. Push lower trigger mech through retainer
b. Install firing rod
c. Install upper trigger mech
d. Install lower retainer & lower trigger mech
e. Install spring
f. Install spring cap
g. Install trigger button top
12. Notch ABS tube for rear section
13. Drill 3/32 pilot holes all exterior locations
14. Install 4mm screws
15. Install spring and extension release lever
16. Notch extension and ABS tube
17. Install rear extension cover cap
18. Install extension stabilizer (sand as needed)
19. Measure and cut extension metal slide
20. Install extension metal slide
21. Install front sight lever
a. Lever first
b. Spring
c. Cap plate
22. Glue ABS piping
23. Install rear sight with spring
24. Install front sight with spring
25. Test!
Step 2: Parts List (see Attached Excel File)
Step 3: Parts Links
Parts list:
Compression Spring Oxide Finish (spring kit) $1.00 https://www.amazon.com/gp/product/B00VDRF25C/ref=oh_aui_search_asin_title?ie=UTF8&psc=1
3d Print filament PLA+ (1kg Roll) $25.00 https://www.amazon.com/gp/product/B079847FG3/ref=ox_sc_act_title_1?smid=A1E7ZJ14B398M&psc=1
4-40 x 1/2" Button Head Socket Cap Screws $8.40 https://www.amazon.com/gp/product/B01I28X76K/ref=oh_aui_search_asin_title?ie=UTF8&psc=1
TagInn Rifled Shell CO2 $80.00 https://www.evike.com/products/72399/
1' of 1/4" Macro line $6.00 https://www.amazon.com/Paintball-Macroline-Hose-Foot-Red/dp/B00BZLNW2Q/ref=sr_1_3?keywords=Paintball+Macroline+Hose&qid=1552763940&s=sporting-goods&sr=1-3
ABS Pipe 2' 2" $4.00 https://www.homedepot.com/p/VPC-2-in-x-2-ft-Plastic-ABS-Pipe-1202/202300519
ABS Pipe 1-1/2" x 2' $2.58 https://www.homedepot.com/p/VPC-1-1-2-in-x-2-ft-Plastic-ABS-Pipe-12015/202300518
ABS hub Hub coupling $0.99 https://www.homedepot.com/p/NIBCO-2-in-ABS-DWV-Hub-x-Hub-Coupling-C5801HD2/100346041
ABS Reducing Coupling $3.00 https://www.homedepot.com/p/NIBCO-2-in-x-1-1-2-in-ABS-DWV-Hub-Reducing-Coupling-C5801HD2112/100348398
Aluminum slider $1.00 https://www.homedepot.com/p/Oatey-12-in-to-19-in-Galvanized-Adjustable-Bracket-33586/302472922
2" - 1-1/2" ABS hub Hub coupling $2.98 https://www.lowes.com/pd/Mueller-Streamline-2-in-x-1-1-2-in-dia-ABS-Coupling-Fitting/3378118
5/32 x 1-1/2"Roller Pins $0.47 https://sutherlands.com/products/item/6310858/hillman-532-x-1-12-in-tension-pin
Hillman Fasteners extension spring 540213, #71 $0.95 https://www.hillmangroup.com/us/en/Home-Solutions/Home-Accessories/Springs/Extension-Springs/Hillman-Extension-Spring/p/540213
Push to Connect Straight Fitting 1/4" OD - 10-32 UNF Male $15.00 https://www.mettleair.com/store/push-to-connect-straight-fitting-1-4-od-10-32-unf-male.html
Push to Connect Straight Female Fitting 1/4" OD - 10-32 UNF Female $15.00 https://www.mettleair.com/store/push-to-connect-straight-female-fitting-1-4-od-10-32-unf-female.html
1/4"x 36" Aluminum rod $4.50 https://www.homedepot.com/p/Everbilt-1-4-in-x-36-in-Aluminum-Round-Rod-801647/204273994
Set Screws $0.35 https://sutherlands.com/products/item/6387187/hillman-4-40-x-38-uss-socket-set-screw
Step 4: Firing Launcher
Firing the launcher with 12g co2 refill and TagInn Pecker Rounds.
