Introduction: MAKE MINI USB LIGHT
MATERIALS REQUIRED
1)MALE USB CONNECTOR
2)LED
3)1OHM RESISTOR
Step 1: INSERT LED
INSERT POISTIVE END OF LED IN POSITIVE WIRE.
Step 2: INSERT RESISTOR
INSERT RESISTOR IN NEGATIVE END.
Step 3:
Step 4: POWER UP.
LAST TWO ENDS OF USB OUTLET ARE POWER OUTLETS WHEREAS MIDDLE TWO ARE DATA PINS,SO CONNECT LED AND RESISTOR TO LAST TWO ENDS.IF YOU ARE USING WIRED CONNECTOR THEN USE BLACK AND RED WIRE TO MAKE CONNECTIONS AS THEY CARRY POWER.
