Introduction: MAKEUP
In this tutorial, I will be teaching you how to create a full face of makeup with ease.
Primer
Eyeshadow Primer
Foundation
Concealer
Powder Foundation
Eyeshadow
Eyeliner
Eyebrow Pencil
Lipstick
Contour
Bronzer
Blush
Highlighter
Mascara
Setting Spray
Angled Blush Brush
Tapered Face Brush
Dense Brush (big and small)
Fuffy Brush (big and small)
Beauty Blender (big and small)
Step 1: Base Part 1
Apply your primer all over your face, making sure it's evenly spread around. Take your beauty blender, get it damp with water, and ring the excess water out. Apply foundation to your face, on your cheeks, nose, and forehead. Stamp the beauty blender on your face, spreading the foundation around, make sure to get alone your neck and chin. Next, take your concealer and apply a little dot under your eyes, take the beauty blender and blend it around the bottom of your eye, covering any discoloration. Using your small fluffy brush, apply powder foundation under your eyes, and using the larger fluffy brush apply powder foundation all over your face.
Step 2: Base Part 2
Taking your tampered brush, dip the brush into your contour and apply it to the hollow of your cheeks. Your contour should be the correct shade for your skin tone. Apply a little contour to the perimeter of your forehead and on the sides of your nose. Using the same brush take your bronzer and apply right above the contour on your cheekbones, on the perimeter of your forehead, and under your jawline. Contour and bronzer should be blending together, with no harsh lines. Using the blush brush, apply blush to the apples of your cheeks and on your cheekbones, the blush needs to blend into your bronzer. Apply a small amount to the tip of your nose as well. Using your middle or ring finger, apply the highlighter only on the part of your cheekbones that catch the most light. When doing this it's best to stand in front of direct light and shift your head to see where light reflects the most off on your cheek. Apply a small amount of highlighter to the tip of your nose and right above your eyebrow.
Step 3: Eyeshadow
Apply a little of the eyeshadow primer on your lids and tap the product around with your fingertip. Taking a small fluffy brush apply a light brown shade to the crease of the eye. The eyeshadow should not touch the bottom of your eyebrow. Taking a darker brown shade and a small dense brush apply the dark brown on the outer corner of your eyes, blend the shadow using small circular motions going around your cease, making sure the lighter brown is still showing above the darker brown. Apply a small amount of dark brown on your bottom lash line, with the small dense brush. Take a shimmer or sparkly shade that's a light pink, brown, or cream, and apply to the lid of the eye. Taking a white shimmer apply a small amount on the very inner corners of your eye. Apply mascara on the top and bottom lashes, avoiding contact with skin. Using a brown eyeliner, line the water line of your eyes, being careful not to poke yourself.
Step 4: Eyebrows, Lips, Setting Spray
There are many different eyebrow products, the easiest for beginners is a pencil. Taking your eyebrow pencil line the bottom of your eyebrows using small hair-like strokes. Once the bottom is lined, fill in the top of the eyebrow, following your natural brow shape and creating a sharp point at the tail of the eyebrow. Apply the lipstick on your lips following the shape of your cupids bow. Once both lips have the product on, rub and pout lips together to get an even spread of lipstick. The final step is setting spray, with the bottle a foot away, spray both sides of your face and let the spray dry.
