Introduction: MANDALATOR LIGHTBOX
this is the one and only Mandaleitor, aka mandalator, I needed a new lightbox for the tattoo studio where I work so i built it
The best tool for creating mandalas!!!
Este es el único e inimitable Mandaleitor, alias Mandalator. Necesitaba una mesa de luz para el estudio así que la construí y se me ocurrió:
¡La mejor herramienta para crear mandalas
Step 1: Lightbox Construction
I needed a new lightbox for the tattoo studio where I work so I bought a flourescent light and built the ligth box from a drawer i found on the street and an old metraquilato sign we had. Just need to remove the "floor" of the drawer and replace it with the white translucid plastic. Then i pasted some aluminium foil to the walls to reflect the light placed inside the box.
Last step put a lot of stickers from your friends and fellow artists and bands and brands to hide the ducktape i used to fix thee box
Necesitaba una mesa de luz para el estudio donde trabajo entonces compré un fluorescente y construí la caja con un cajón que encontré en la calle al que le quité el "suelo" y lo reemplacé por una plancha de metraquilato de un cartel viejo. Le pegué papel de alumino por las paredes para que reflejase la luz situada en el interior.
Por último puse un monton de pegatas de mis amigos, bandas y marcas afines para esconder la cinta guiri que usé para reforzar la caja
Step 2: Mandalator Itself
Next build the mandalator itself. I have to thank MandalaJim ( http://mandala-jim.deviantart.com/ )for his tutorials, they're sooooo helpful.
Go to his site and download the mandala template at his tutorials http://mandala-jim.deviantart.com/art/Mandala-temp...
Print it
Cut it
Make a hole in the translucid plastic of your lghtbox, I used a tattoo needle heatened with fire
Paste the mandala template to the box placing the hole in the center
Then I cut the needle i used before to have something to stab the papers with.
Its ready to use
Ahora construiremos el Mandaleitor en si mismo. Debo agradecer a MandalaJim ( http://mandala-jim.deviantart.com/ ) por sus utiles tutoriales
Ves a su pagina y descarga la plantilla de mandalas de su tutorial http://mandala-jim.deviantart.com/art/Mandala-temp...
Imprímelo
Córtalo
Haz un agujero en el plastico traslucido de tu caja de luz, yo usé una aguja de tatuar calentada con un mechero
Pega la plantilla al plastico usando el agujero como centro de la plantilla
Despues yo corté la aguja de tatuar para tener algo con lo que clavar los papeles a la mesa
¡Ya està listo para usar!
Step 3: Creating Mandalas With Mandalator
fist place a paper on the template
Draw a section of your future mandala
Put another paper over it
Copy the segment
Spin the second paper
Copy the segment
Repeat till the circle is complete
Enjoy!
CREAR MANDALAS CON MANDALATOR
Primero pon un papel sobre la plantilla y clávalo
Dibuja una sección de tu mandala
Pon otro papel sobre él y clàvalo
Copia el segmento
Gira el segundo papel
Copia el segmento
Repite hasta que completes el círculo
Y.... ¡A GOZAR!
